I still can't fathom why they didn't do the job fully and fit it with a presence control though. They even left the appropriate space on the control panel.
I wouldn't be surprised if it was just about giggable either - through a 4x12" or maybe a 2x12" with 100dB speakers, anyway. It might not be loud enough to be heard in the room without mic'ing it but it probably would be on stage, particularly if you don't want a clean sound.
(I'm basing that on the Blackstar HT-1 which uses a similar push-pull ECC82 power amp.)
I borrowed a HT-1R recently, and although I didn't try it with a band it had the right sort of tone and dynamics I like, and I'm sure it would have been loud enough if it was mic'ed - at least when I ran it through a pair of V30s, it wasn't as good through its own little 1x10".
So I like either 100W amps, or 1W...
It was certainly a lot louder - as well as much chunkier-sounding - through them than the 1x10".
Ah yes, that was it, 3db is equivalent to 50w to 100w. Cheers.
The 50th series are really not amazing inside, and to me sound fairly average even through a much better speaker. The combo version of the JTM model I tried was pretty poor, to be honest. A shame, because it looked nice too.
If you ever see one used I'd recommend picking one up, even four years later I'm still as enamoured with mine :-)
Sounded great. No stompboxes needed either!!
