Pickup testing guitar
FelineGuitarsFelineGuitars Frets: 11653
edited July 2016 in Made in the UK tFB Trader
We built a pair of guitars to test out pickups. One had an alder body and the other had an ash body.
These had quick change components that incorporated a cut down pickguard and side part to the body.
We built a standard pair of strats but with a difference - the top section on one side is a separate piece. The holes are where bolts from the back can hold onto the top pieces
Here you can see we made a few pieces of interchangable tops so we could have a couple of pickguards loaded to compare and contrast different pickup types
here is one of the lower bits on it's own
You can see that the top part just slides into place
We added some magnets into the top of the body part that will grab onto steel discs in the test pickguards
A fully loaded pickguard connects with aquick connector
Slide the pickguard and pickups into place .
The magnets will grab the pickguard and a single bolt will hold t all steady (although there are 3 that can be used.
All in place and ready to plug in and try out
Here we go - both tester guitars and the additional pickguards and side parts, as well as the router template to make more pickguards
  • guitarfishbayguitarfishbay Frets: 7964
    Seems like a good idea for what you're trying to achieve.
  • RolandRoland Frets: 8798
    What do your pickup suppliers think about this, or haven't you mentioned it to them
    That's a great idea Jonathan -b ut what if you want to test a HSH (for instance) or pair of P90s etc. Wouldn't a swimming pool have been a better idea?
  • FelineGuitarsFelineGuitars Frets: 11653
    Easily modified for that. Taking it to show Ash tonight too
  • TTonyTTony Frets: 27795
    edited July 2016
    Looked very neat from the brief look I got at it this evening @FelineGuitars.
    You could find that there's a market for something like this ...
  • DrBobDrBob Frets: 3012
    Even aside from the functionality of it (which does look great ) I'm quite into the alternative take on the classic Strat pickguard !
  • richhrichh Frets: 453
    That's genius!
  • axisusaxisus Frets: 28348
    A great idea superbly executed.
  • thomasross20thomasross20 Frets: 4437
    Very cool!!
  • LebarqueLebarque Frets: 3922
    If there are some A5 strat pickups out there better than Rocketfire Total 60s, please let me know. I haven't found any!
