How do you hold the pick?
monquixotemonquixote Frets: 17683
in Technique tFB Trader
I've always held the plectrum between my thumb and my index and middle fingers. It was too ingrained to change by the time I realised it was a bad habit.
The only time it annoys me is when I need to hybrid pick as I have to do it with ring and pinky only.
I've always considered it a flaw in my technique which might explain why I'm not an especially fast player so I was quite heartened to discover that Steve Morse plays this way (so I have no excuse).
Recently since getting my PRS singlecut my usual picking technique has started to make my thumb hurt so I've started holding the pick with just my thumb and middle finger. Apparently this it now EVH does it (keeping the index free for taps)
Anyone else have weird picking?
  • I hold mine... Okay, I'll describe.
    First finger is hooked around fairly tight, thumb presses pick against the side of the first finger/nail.  By rolling my thumb, I can adjust the tone I get from picking (typically flatter for a hard, heavy attack with lots of brightness and angled more for a 'rubbed', softer attack, useful for smoother sounding solos, chords and fast stuff).
    That's not to say I can play fast... :S it's more of a tonal decision for me.  I find the pick attack, and the type of pick (I have now settled on Jazz III Ultex) affects the tone in a huge way, much more so that something like a different saddle material.  For more strummy songs, I use a Jazz III Nylon, because it has a brighter 'snap' to it, which helps make my warm, slightly dully eq'd Bandit clean channel get a bit more sparkle (dull so it can take a boost nicely).
  • axisusaxisus Frets: 28347
    There are quite a lot of well known unconventional players, I remember seeing a thread on another forum about it. The only one I recall off the top of my head is Marty Friedman - So whatever works for you really!
    I'm a bit weird in that I don't use a plec for electric guitar. I use my index fingernail as if it is one. Plectrums have always felt like a barrier to feel for me, something in the way. I used to find that they were OK for general alt picking etc, but very difficult for strumming, they always seemed to ping off. I started off without them, but was hampered by my nail getting thin and breaking all the time, so went to plecs on and off. The big breakthrough for me was about a year ago when I discovered that you could use acrylic to strengthen your nail, since then it has been no plec all the way.
    I like to strum with my fingers, I like to fingerpick, I like the softness of a note if you pluck upwards with the flesh part of your finger, or down with your thumb, I don't have to put the plec anywhere if tapping, I can play two adjacent strings simultaneously without the ones inbetween - they all feel like 'extras' that I can't do with the plec.
  • EricTheWearyEricTheWeary Frets: 16303
    edited January 2014
    Thumb and index finger,use the next two fingers for a bit of hybrid picking. My main problem is around not being able to relax my picking hand enough, especially live or even just rehearsals. I can bend a 1mm pick from holding it too tight, whereas on a good day I hold the pick (plectrum, what ever you prefer) quite loosely and this is less stressfull on the old joints and much smoother and quicker.
    Nothing very clever about my hybrid picking, I tend to bring in a spare finger where somebody else might use a better pick technique so it is quite lazy and awkward.For example, a basic blues turnaround ( these things are hard to describe from memory, hope this makes sense!) like:
    -4----3----2---1--0--------------
    4-4-3-3-2-2-1-1-0h1---------2
    -----------------------------------1
    ------------------------------0-1-2
    I would use the pick on the G and my 3rd finger on the high E, whereas it would be smoother using alternate picking, and then pick, middle, 3rd on that little chord at the end rather than a strum.
    There is a cool variation on this lick that I remembered from somewhere the other day:
    ---4----3-----2---1----0--------
    44--33---22--11--0h1-------2
    if you mute on the double notes on the G string and give a good upwards pluck on the high E string notes it becomes chicken pickin and justifies my lazy arse technique.
  • RolandRoland Frets: 8767
    Conversely, I keep my first finger straight, and place my thumb across it at right angles. This is because I often play without a pick, and it is natural (to me) to use a similar finger position whether there is a pick there or not.
  • mike_lmike_l Frets: 5700
    Between first finger and thumb. Finger curled round, and pointing back towards my wrist. Middle/ring/little finger clenched tighter for faster/heavier picking, looser (or splayed) for lighter strumming.
  • carloscarlos Frets: 3465
    Index and thumb extended grip, like the grip you'd use to pick up a pencil off a table. Believe that's how George Benson, Tosin Abasi and a few others hold it too. My thumb bends backwards at nearly a right angle which helps.
    As @Jalapeno would say: "This thread is useless without pictures"
  • monquixotemonquixote Frets: 17683
    Good point
    My normal 3 finger grip
    My new 2 finger grip
    Interestingly my finger points down at the pickups. It had never occurred to me that it should curl back, but all the pics on google of people seem to show that grip. Feels very unnatural to me.
  • JalapenoJalapeno Frets: 6399
    I am humbled that my good works have been finally recognised ! ;)
    Feedback
    Good point
    That means your scope for pick & finger style is limited .......
    Feedback
    Absolutely.
    I wish I could play with the index finger, but it just feels weird.
  • dafuzzdafuzz Frets: 1522
    You *can* change your picking! (Sounds like the world's crappest self-help book but it's true). I picked the same way for about ten years, realised it was holding me back, and made a change. My thumb wasn't used to it and it hurt for a bit but I got there. Within a few weeks I was as good as before and just kept on improving after that.
    At the start - as with any habit that needs to be broken - you need to consciously make yourself do the thing differently. It soon becomes second nature though.
    Also: I can go back and do it the old way whenever I want.
    All practice and no theory
  • vizviz Frets: 10732
    Look at evh - he has the best pick action of all of em.
    From what I understand the second picture is how EVH holds his pick.
    Yes though sometimes he puts his index on it as well. Holding between thumb and middle helps him do his unbelievable fluttering wrist action swivel flurries.
    edited January 2014 tFB Trader
    I have absolutely no idea what you are talking about, but I want to be able to do it as well :D
    I have always found it very easy to tremolo pick so maybe that's something to do with how I hold it.
    I could quite fancy learning some EVH tricks at some point.
    How do you hold it?
    edited January 2014
    Not him but:
    dafuzz said:   You *can* change your picking! (Sounds like the world's crappest self-help book but it's true). I picked the same way for about ten years, realised it was holding me back, and made a change. My thumb wasn't used to it and it hurt for a bit but I got there. Within a few weeks I was as good as before and just kept on improving after that.
    At the start - as with any habit that needs to be broken - you need to consciously make yourself do the thing differently. It soon becomes second nature though.  Also: I can go back and do it the old way whenever I want.
    I certainly agree that you can re-learn a lot of aspects of playing, whether that is bad technique or picking.  It just takes going back to basics and putting some serious time into concentrated practice and use of the new technique, until your synapses have built new pathways and are so used to it that it becomes second nature, and is easily and subconsciously performed.  (if that makes sense)
    @dafuzz, I am curious, you didn't say what your pick holding technique was, or what you changed it to.  What was the restriction that made you change and what benefits did you see from the new way?
    Basically I angled the 'front' of the pick (ie the edge closest to the neck) towards the ceiling. My thumb was bent into a kind of u-shape. It always held me back from sweeping and fast alt picking, but far and away the worst side effect was that I had to hang my guitar a lot higher than was cool when I played standing up! :D Tone was fine though.
    It was a tad annoying that early on in my playing I took some lessons from a teacher at school and another privately. They both commented on my picking style but did the usual thing of saying "there is no right way to pick, whatever works for you" etc. Trouble is it didn't bloody work for me.
    So, eventually, I learned to angle the pick down towards the floor in a more typical Paul Gilbert fashion (it was Intense Rock I & II that really brought it home that my style had to change) - now I can play with the pick angled 'flat' against the strings, or I can slice it 'upwards' or 'downwards' depending on what I'm doing and the tone I'm after. *Everything* is easier now :)
    I know this is a thread about picking, but the same holds true of fretting. In order to minimise travel I *really* slowed down the pace and concentrated on having my fingers float above the strings as close as possible at all times and only do the minimum amount of movement requireed to fret the note and them lift back off to the starting position as soon as the next note is fretted (see Troy Stetina's Mechanics book for a better explanation). Again, it hurt at first! After yonks of doing that I can still go back and have my fingers flap wildly around the place if I want to, if the style calls for it, but now it's a choice rather than a restriction.
  • stickyfiddlestickyfiddle Frets: 27262
    I used to hold my pick as Monq describes, then moved to index finger only and now play more with just pads of fingers than pick, at home at least. If I'm playing lots of chords or stacato riffs then a pick can't be beaten, but for a lot of lead lines fingers only can make things far easier.
