We use two of these linked with a long DMX cable. The one on my side of the stage is configured as the master, and t'other as a slave. We use the sound-to-light setting, with the sensitivity set very low so that it only activates from the bass drum or loud chord, ie on the beat of the music. I use the footswitch to kill the lights between sets.
https://www.amazon.co.uk/Kam-Lighting-Led-Partybar-V2/dp/B00603XK8K
Where floor space permits we have static blue LED pars on the floor to light the drum kit. Chrome shows up well in blue.
If the pub is large enough I put three or four long PAR cans on a lighting bar and stand at the back of the room, aimed at the mics, to pick out our faces. They have straw and blue gels to get the right colour. These are old fashioned bulbs, delivering lots of heat, so I'm glad to have them far away. They look like these:
http://www.thomann.de/gb/stairville_par_30_e27_black.htm?sid=b159841dfc498ae10ec84e51e2002f4b
Lastly, we carry a back drop. Nothing fancy. A 5m x2m sheet of black cotton which I bought on the market. My wife hemmed the loose edges, and I put in metal eyelets so that it's easy to hang with string or cable ties. We can pin it to the wall, hang from a washing line, or from a gantry which I picked up on his forum. For me this ties everything together, and hides the bloody dartboard, television screen, and cabbage rose wallpaper.
We have party bars at the side of the stage but there isn't always much room and sometimes the light in the room means they are washed out. We also don't have a backdrop so lighting up the dartboard isn't always the best. Good point about the sensitivity, endless flickering is annoying.
In the blues band we had a couple of very cheap rotating things the drummer picked up as Argos seconds ( he used them as a lighting rig when practising at home!) but they only really did anything in very dark rooms.
I've played pubs that have lighting rigs fitted but the aim seems to be to blind performers rather than do anything useful.
I blame the smoking ban for the lack of ambience.
Lighting upwards from the floor can cast weird shadows on your face. It's better to put a PAR can on each speaker stand shining across the performance area.
Trying to use lights down on the floor to the front or front/side will blind the guitarist/bass players.
You will get shadows lighting from off to the side but it can look dramatic and you're not trying to light up a Theatre show... it's rock so a bit of mystery doesn't hurt.
Here's a shot of band taken with two lights washing the back wall and the other two on a high stand on one side. Using the lights at the rear gives the 'stage' some depth if you get them different colors to the side lights.
I'd personally avoid having the classic 4 lights either side of the band flashing away like crazy. As said above, if using sound level triggering set sensitivity low so they mainly reach to the kick.
