1. Are you using anything else apart from the mic in shot to track the guitar?
2. I can hear the reverb, but what else did you do to the track?
Ta, N
"Recorded using the guitar's undersaddle pickup and an ADK condenser mic, into a Tascam DR-100 digital recorder with a touch of reverb from the TC Electronic Hall of Fame."
I can detect the ust and it's better suited to nylon string than steel
I used the mic for the right channel with the guitar's Fishman undersaddle transducer for the left channel (which went into a TC BodyRez to remove a bit of the piezo sound) and put both through the stereo inputs of the TC Hall of Fame reverb pedal. The stereo outputs from the TC were recorded into the stereo line in of the Tascam DR-100.
Finally I added a touch of multi-band compression in Logic to the stereo file.
Hope this helps. I'm always happy to answer any questions! I was quite pleased with the final sound, for a relatively budget set up (I think I got the mic for 40 quid off ebay a couple of years back, but it's quite a nice condenser).
