Taken from the manual, Mesa Boogie describes it as follows:
'Simul-Class power is like having two different kinds of power operating simul-taneously on each channel of the amplifier. One power section is wired in "Class A Triode" and uses two EL-34 tubes. "Class A” power is the oldest and purest form of amplification; it’s warm and "vocal" tone is the heart of the Simul-Class circuit. The other power section uses two 6L6 tubes, wired in the more modern and efficient "Class AB" configuration; this section provides the bulk of the "muscle" in the amplifier. And by combining these two "classes" of power design, the Simul-Class circuit reaps the rewards of both. The 30 watts of vintage Class A tone combines with 65 watts of efficient Class AB power to produce a total of 95 watts per channel of the warmest, most musical power you've ever heard! Or you can use the "Class A/Simul-Class" switch to turn off the Class AB (6L6) sections, and run the Class A (EL-34) sections by themselves. This allows you to drive the amp harder for greater power amp distortion, but at volume levels you can more easily control.'
It also features presence switches on the back for each channel....
Cosmetically, it does has a few scratches but given it's age it is in great condition, and is fully functional. It could possibly benefit from some new EL34's, but it's certainly not a necessity - it sounds great as it is! I'm based in London, looking for £500.
Pictures:
Check the post below for links to a few videos/recordings I made using the 295 in combination with my Mesa Boogie Quad preamp(also for sale):
'Most guitar players have experienced the dreaded "tap dance" – having to stomp on multiple pedals and footswitches to select the sound you need. It’s a hassle and can detract from a performance.
MIDI can be used to solve this problem. MIDI controlled effects units have been available for decades. It’s a tried and true solution. You can control a whole rack of effects using a single MIDI controller. However, most guitar amplifiers have no MIDI capability, so you’re stuck with using a separate footswitch just for the amp.
That’s where the Amp Gizmo comes in. It will allow you to control all of the footswitchable features of your amp from any MIDI controller. You can finally put your amp’s footswitch away and control your amp from the same MIDI controller you’re using to control your effects!'
The unit is in great condition, and has performed its job without any problems. Due to the isolated switching jacks I've never had ground loops issues with it, and it was a breeze to set up.
I'm based in London, UK. Looking for £200.
Photos:
https://vgy.me/UX3UbF.jpg
https://vgy.me/Y7bUGv.jpg
https://vgy.me/VORJev.jpg
Do you have any clips of the Marshall.
Also What Mesa Boogie is in the pic in the Cream Headshell.
Thanks Ian
