Hi, I've been playing for a while now and while I'm not very good at it, I've been making slow and steady progress. I want to learn more but I'm not sure where to go from here.
I basically know all of the chords, barre chords and stuff like that but would like to improve my lead playing.
Currently I can play intermediate riffs and some simple solos. Examples of what I can play are:
The Raconteurs - The Switch and The Spur.
The White Stripes - Offend In Every Way
The Intro Solo of CSN - Long Time Gone
The Solo in The White Stripes - I'm Slowly Turning Into You.
So what do I learn next, any tips on how to improve?
To give you an idea of how far I've got, I'm not really sure what that means. I know the pentatonic minor scale and can play it up and down, but apart from that I don't know anything else about scales.
Learning to harmonise the major scale is your next task.
I can start you off when I'm not on iPad, I'll check in tomorrow and write that post.
If I forget PM me, I've got a slightly hectic day tomorrow.
OK thanks, I'll be pretty busy tomorrow so won't get much chance to play, there's no need to rush.
You do place it on the guitar but only after you have thought your way through it.
Ok, @olafgarten this is what you want to do- harmonise the C major scale, which is C D E F G A B C
Chords, as we know, are made up of stacked 3rds (please no-one start talking quartal harmony).
So a C Major triad is C E G.
So you are starting at C and skipping ever other note.
Now extend that one more interval.
C E G B
This is a C Major 7th chord, because it is a C Maj triad with a major 7th interval.
There are 3 other types of 7th chord.
The minor 7th, the dominant 7th and the minor 7th flat 5 (also called the half diminished).
If you harmonise each note of the C major scale in this fashion you get the following:
C E G B = C major 7
D F A C = D min 7
E G B D = E min 7
F A C E = F major 7
G B D F = G dominant 7 = G7
A C E G = A minor 7th
B D F A = B half diminished
There is another way of writing these chords in relation to the tonic C which is:
C maj 7 = I
D min 7 = ii
E min 7 = iii
F maj 7 = IV
G7 = V
A min 7 = vi
B 1/2 dim = vii
Now take this through the cycle of 5ths.
There is a good few months work here.
If you don't know what the cycle of 5ths is then say- and we can have a conversation about that.
So any time you see a maj7 chord you will know that in most situations that it will only be a I or a IV or a particular key.
When you see a minor 7th chord you know that it will probably only be the ii, iii or vi of a particular key.
When you see a Dominant 7th- well, the Dominant 7th gets tricky because of something called secondary dominants- but I'm not going to go into that now.
Let's ignore the 1/2 diminished right now.
I'm going to stop now and let you pause for breath.
If there is anything above that is unclear then just say.
