On my strat-parts-caster, I have a Gotoh 6-point vibrato/whammy/trem/whatever...
I've got the unit fully floating, but up until recently I've not been fitting the arm, and only used the trem unit to get nice little 'shimmies' using the heel of my palm on the bridge.
Having listened to Guthrie (and being more than a bit hopeful ;^), I've started fitting the arm and doing a few dives (lovely...)
But all the time, I've had another problem that I've been struggling with. I'm a bit of a string bender and if I play double-stops, for example playing the E on the 5th fret of the 2nd string, and bending the 3rd string 7th fret up a tone also up to E - as I do it the E on the 2nd string goes flat...
It is obvious what is happening here, but trying to keep the 2nd string in tune with a micro-bend, whilst doing a tone bend on the third is hard work...
I did try blocking the trem at the bridge side and loosening the springs, and of course that worked (and improved the tone too!), but of course the trem itself is now inop for dives (although I can still manage the shimmies) ...
I got myself a Hipshot Tremsetter, which works... *almost*, but not perfectly (and is a bear to set up...)
My next step is to try blocking the trem on the neck side and tightening the springs - that will at least leave me with my dives... (but probably no heel-of-the-hand shimmies).
... but how do others deal with this - or isn't it a problem??? (A Strat-shaped-object without a reasonably functioning whammy doesn't seem right somehow...)
Thanks
Alan
Interesting this.
I'm having a similar quandary with my PRS at the moment and wondering which way to go.
Some good info here and reveiws of the various devices available:
http://joe.emenaker.com/TremStabilizers/
Hello all, by the way - new poster.
@AlanP
Have you tried a bit of "Nutsauce" on the nut (Obviously) and anywhere else the string is in contact (Bridge/stringtrees etc)
As I have my Strat bridge set up to float and even with some quite large (Think David Gilmour-esque) bends and don't lose any tuning stability.
Ah, I see. I seem to have developed a little technique (All my bridges float) whereby I put a little pressure on the bridge when I'm bending so the bridge pulls the rest slightly sharp. It is only fractional though, and just enough to stop others going flat.
Easier to do than describe.
If it helps, my picking hand basically rests on the bridge, and it's a minute twist of the wrist to push the bridge sharp.
I'll see If I can do some photo's this afternoon.
