Not on here much, but this came up on my YouTube thing this morning and I thought some peeps may be interested.
Drewmen guitars are making aluminium bodies in the UK. they have a couple of shapes- a LP and a rather awesome looking Thinline slash hole Tele.
Not cheap- about a grand for the body only,no necks that I see either. Seem to be up for custom shapes and OEM work as well.
As an alternative to E.G.C with import costs etc might be worthwhile considering.
Website here-
http://drewman.co.uk/ A couple of videos-some bloke called Steve Hacket playing one. Also Crimson Guitars unboxing, if you have the patience to wait thru the waffling.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Sorry I didn’t explain myself very well, I do realise the finish you see is machined. What I meant was, a casting his made then it then goes on to a CNC workstation where all the roughness is taken off, then machined to the correct thickness and then the finish patterns are machined into the surface.
Many years ago I did have a very boring job, I used to run a CNC workstation, where I machine rough castings from the foundry into the outer casings of very large water pumps. It could well be, they machine from a solid block but the cost would be phenomenal, I would guess 90 percent would turn into swarf, even the biggest CNC workstation would take a very long time to remove all that material.
Interestingly, the outer cases of the water pump were first made from a solid block of some kind of resin. It will then be machined to the final shape, this would then be sent to the foundry, who initially made moulds from sand or whatever it is they use in foundries.
If they had a very large 3-D printer, now the shape in a CAD system they could print them, don’t know what they would sound like, pretty rough I expect. You never know with a lot species of wood becoming difficult to get it could be the future 3-D printed guitars (one hopes not).
I hear you about quality guitar building woods becoming more scarce in the future......I guess different materials will be found....
Rosewood among others are now subject to increasing restrictions and it would seem that now the tropical hardwoods can't be sold they are just burnt in some area to create farmland. A ridiculous situation like fishing quotas where dead fish are thron back as they are too small.....
coat... I'll get it.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
https://instagram.com/p/BbbWr11FYBp/
https://instagram.com/p/BbYDlSQFreE/
if it had to be metal then solid not hollow, and maybe copper or a 'warmer' metal. aluminium has very industrial associations for me. cold, sterile, harsh.
i'd quite like a solid-body glass guitar though. maybe with a glass neck too.
maybe like murano glass made out of compressed and blended colours, blacks and deep purples and scarlets.
and it could have a little light/heat source in, so the rich colours could glow gently in the dark.
https://i.pinimg.com/736x/12/cf/c4/12cfc4e96a9869fda8dfae9d33e65949--art-deco-table-lamps-art-deco-design.jpg
