Fitting a pickup to an acoustic?
daveyhdaveyh Frets: 684
Any advice on this? I know nothing about these, but basucally I'm thinking something simple with an end pin jack to fit to my LAG and kept everything else happen outboard. Is this easy for someone reasonably competent? What's a good pickup? Cheers in advance.
  • Pure mini. I installed mine myself but @ICBM tidied it up at the bridge end for me. I'd pay for somebody to do it TBH.
  • ICBMICBM Frets: 72490
    K&K Pure Mini as thomasross said. He actually fitted it perfectly well, I just improved the jack wiring slightly :).
    Simple, reliable, easy to fit and sounds good.
  • LewyLewy Frets: 4238
    Another vote for the K&K pure mini
  • It really is the most non-invasive option, doesn't cost a fortune and sounds great. I'm 100% glad I got it over the anthem/lyric etc.
  • daveyhdaveyh Frets: 684
    Cheers guys, I shall investigate this
  • You want another vote for the K&K? My Larrivee loves the one I had fitted.
  • Is the K&K mini any good for a 12-string?
    If you must have sex with a frog, wear a condom. If you want the frog to have fun, rib it.
    Yes. Good for any guitar with any string spacing or type exactly because it picks up from the guitar and not the strings.
  • Ta for that, @ICBM. An order shall be setting forth in due course then.
