Worked well, but kinda heavy in use, and a metric ton in weight
the lock nut was the weak link.
the first few pics on google are mine
Instagram
somewhere at the back of a fading memory bank I recall they where designed and/or built by a camera company
At least if I see a used guitar again with 'old holes' that no longer appear to have a purpose I can think Shift 2001
One?
You underestimate Harry. He's probably got at least a dozen of them.
Okay, a kahler needs routing and there is no getting away from that, but it also needs a fairly specific neck angle to get the most out of it, so you either need to shim the neck or recess the whole trem
this is similar, even with the big rollers you need the saddles high for the best experience
Instagram
They were a brilliant idea in theory - not only not involving routing (although there are still two screw holes in the body and four in the headstock, so still non-reversible) - but capable of an interesting trick… if you set them up just right, you can get them to bend a chord in tune, because the second set of saddles at the back adjust how much each string detunes by, like a Steinberger Transtrem does.
Although whether you actually want that in practice is a different question - it makes the guitar sound more like it has a synth pitch-bend on it rather than a 'trem' - which all sound different on guitar exactly because they cause different amounts of relative detuning.
They do also massively suck tone and sustain.
From memory they use some sort of torsion spring inside that barrel arrangement under the rear saddles, but I can't remember for sure. I've never tried taking one apart, I suspect it might not be a very good idea!
I learned my lesson, setting up a TransTrem on a strobe tuner will drive you to madness
Instagram
still trying to find on google any guitar that was factory fitted with one
Instagram
Instagram
Instagram
Not at the moment, but I did have a short while ago!
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
I had another about six or seven years ago - this time a twin humbucker Tele with one of these retro-fitted. Time isn't kind to these... the threaded section where the trem arm screwed in had gone very baggy, meaning the arm clonked about and something to do with the pivot was worn meaning the return to pitch was woefull. It was so shit, that I removed it from the guitar and fitted a top-loading fixed bridge in its place. I sold the trem unit on eBay, saying it was fubar for £75... I was stunned, even more stunned that the buyer paid the postage to California...
Even worse than a Bigsby.
https://s-media-cache-ak0.pinimg.com/originals/2b/f7/f0/2bf7f00a43dd67ae0a7656bfbb60f281.jpg
It gives it a real 'rocket' vibe somehow and looks great. On anything else, I probably agree with you .
