I know there has been loads of topics on this, but my Vintage V6P (Strat Like thing) has an issue.
Whenever I play acoustically and am strumming chords the Low E string is hitting the top fret and making a metallic ringing noise which is really annoying, but the guitar plays really nicely and I don't want to ruin that by raising the action.
Using some picks as feeler gauges, at the first fret the action is less than 0.6mm (smallest pick I have) and at the 12th it's around 1.56mm.
Should I raise it? What is the method of raising a Strat Hardtail (I only have experience with TOM's)
1.5 mm action at the 12th is low for my setups......can't say for anyone else.....
When I set nut action I fret at the 3rd and file the nut slot until there is a tiny gap between the string and the first fret.
My action at the 12th is between 2.00 and 2.5mm.
Neck relief is about the thickness of a 10guage string with the steing held down at the 17th fret with the strings fretted at the first with a capo......measure/sight the gap at the 7th fret
To raise the action you need to adjust the allen screws on the saddles, keep the saddles parallel to the face of the bridge plate...
Lots of variables to consider...
Someone else will probably come along with other ideas soon.....
Then check the relief by holding the guitar in the playing position and fretting the string at both the 1st and 17th frets. Look at the gap between the string and the 7th-8th frets - it should also be about 5-10 thou. (You can do both these things with all six strings obviously, to check the nut and the neck are even across their width.)
Then finally when these two are right, you can check the action - you can't really before, since they both affect it. 1.5mm is very low for the low E even on an electric guitar, 2 to 2.5mm is more typical.
Strats have one further problem which is that if the neck pickup is adjusted too close to the strings, it will pull them down and can cause them to rattle even when the action is high enough that they shouldn't. It can also cause odd overtones or even false notes, especially when you play around the 12th fret.
I try and get all mine like that, it does sound like yours could be on the low side
(formerly customkits)
You can either fit a new nut, or try to fill and refile the slot. There are lots of YouTube vids showing the baking soda and superglue filling method.
Turns out there is a tiny amount of Buzz on frets 5 + 6 on the low E, but it's improved.
