If any of you subscribe the Stew Mac newsletters, you would have seen some time ago they were advertising very light T/C’s made from Obeche. This is not a wood that I have come across before but, having received several emails asking if I could make T/C’s and Strat’s bodies from Obeche, I made several phone calls to wood suppliers and eventually found one who could supply Obeche thick enough to make it guitar bodies from. I eventually found one, but they are down the West Country some six or seven hours drive away, too far to go have a look at it, so I ordered sufficient for 4 bodies. I’ve just completed the first T/C, it only weighs 3 lb 3 oz’s. The amazing thing about this wood when you tap it, it has a real ring to it, which you would normally only get from heavy South American mahogany. I will make a Strat next week hopefully, I’m almost sure it too will only weigh just over 3 lb.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
most will be surprised to see obeche as a pale lightweight wood given gibsons use of it as a dark fretboard wood in recent years
Shergolds were made from it, PRS have used it too on some low end models. Probably seen as a budget option, but I quite like it
Instagram
At only 3lb might neck dive be an issue?
