Decided to treat myself for Christmas and buy a Fender Bassbreaker 15w head
My question is about Cabs- there are 2 to choose from a 1x12 and a 2 x12
The 1x12 set up with amp is around the £660 mark from Andertons
The 2 x12 set up is around £760 from GAK - all with free delivery- my question is - would it be worth the extra £100 for a 2 x 12 cab, in terms of sound, output, tone etc- talking small pub - club gigs etc Mic'd or straight to amp
http://i.imgur.com/1ccsHtG.jpgI apologize for the noob questions, I am usually a combo man and this will be my first venture into Heads n Cabs
Les
Les
Thoughts anyone ?
I have had combos for years and really fancy a change
Les
However, the 15 does have a good emulated line out so you can use that for gigs, depending on the PA.
contactemea@fender.com
Hot rod deluxe!
^^Agree ^^. The HRDX is however a fair bit more expensive new. The 2x12 format of the Bassbreaker moves some serious air though and it can be plenty loud if needed.
I came home without one.
I ended up with a second hand HRD which suits my needs so much better and to my ears sounds better. Never had a problem with it only being a 1x12 as anything bigger than a tiny pub and it's likely to be miked up anyway.
Les
