And as Eric says they're poorly designed and built, and unreliable. It's difficult to completely fix the faults too.
The mains transformer *will* overheat and fail. They run ferociously hot. The output transformer may pack up too. New spares from Marshall are laughably cheap (about a tenner each IIRC) which shows how cheap they were to make. No point fitting one though, as they'll fail again.
I had one of these amps and made it reliable by fitting a non-Marshall OT, and a mains fan to cool the new Power Tx. I also cut a hole in the top of the cab and fitted a grill to let the heat from the valves out of the chassis. (yes, Marshall designers, to get a flow of hot fluid you need an inny and an outy).
With this done, it was reliable. The valves are biased verrry hot, and it's not adjustable, so only use the Sovtek 5881WXT, which are tough as old boots and will hack it.
Was it worth it? Dunno. The sound wasn't bad actually. Not classic Marshall, but I gigged it a few times (with a 1x12 extension cab) and at gig volumes, it came to life a bit. So, not a bedroom amp, but unreliable to gig without mods!
They did leave an 'outy', it's the slot about an eighth of an inch high above the chassis where the 'bumps' around the bolt holes stop it closing up completely . Or at least that's what they must have been hoping… until the heat softens the glue and the vinyl peels off and blocks it. Woefully inadequate in the first place anyway.
Never had any of those (on my amps anyway - I've had 2 other JTM60s as well!!) I think those sound like mainly heat-related issues, and once you've got the fan in the back, the amp becomes no less reliable than other Marshalls of the same era. So yes, all the faults you mentioned!
But they seem to have a lot of inspired by circuits of Marshall and... Well, loads of brands. Are they actually any good? I have to admit, I heard a high gain Marshall style they did and thought it sounded a bit dead (jcm 900 clone - I quite like the sound of the 900 sl-x), which I assumed was down to corner cutting for the circuit and using really cheap parts.
Like I said, the 6505+ combo is priced well enough to make that clone close to pointless.
They have other interesting stuff though, and it is dead cheap. I'll need to look into them more. Then again, jet city stuff isn't expensive and they're supposed to be great.
Bugera overpriced?
