I used a schaller signum wraparound bridge on a set neck tele I did and I could go modern again or go for a more traditional looking wraptail bridge, I'd like more opinions and preferences
(formerly customkits)
Yeah I love the limba I've got a dc cut out when I get round to it oh and a firebird body
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170111_114134_zps5pwcrgu0.jpg
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20161223_171615_zpszo83jbor.jpg
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170116_132443_zpsvh0ongvb.jpg
The only thing i did different is glued 2 little ramps on either side of the tenon so i didn't ramp the body down too much at the front and lift the body up and route my neck plane on the pin router
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170119_171420_zpsowchlcxe.jpg
I also taper my boards first then cut slots by hand, it's the way i got taught and it's accuarte, i've tried doing it square but i don't like it, try checking with a sliding bevel if your slots are 90 degress after tapering a square board, it only has to be out by a smidge on the centreline
I put cellulose nitrate dots in first then radius
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170104_131013_zpsnae2yycs.jpg
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170110_124734_zps14jic1kd.jpg
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170110_124745_zpsrb5zmlxh.jpg
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170110_125530_zps9xqlquli.jpg
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170111_163238_zpsg2e7oyg5.jpg
Obviously i went with my headstock but i modified it slightlly wider to straighten the e strings and i think it looks better too
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170119_171532_zpslkh0yxoi.jpg
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170202_152400_zpsxjyh6zpv.jpg
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170201_235225_zpsbepg0uxb.jpg
Its an interesting point, but I don't think it makes too much difference.
I slot whilst square because its easier to line a square board up in the slotting jig I have. With a tapered board the error may occur when fitting the non-square board into the jig. I have done it whilst tapered but was less sure the slots were going to end up perfectly perpendicular to the centre line
But either way you would expect the error to be small and would not really matter if the error was consistent on each fret If the frets looked to be on a slant obviously that's terrible, but if they are all on the same slant, along with the nut slot* it would actually still work totally fine. Rickenbackers Slanted fret models are a good example of this taken to the extreme.
Anyway, Horses for courses... Enjoying the thread
* that should read "uncompensated nut slot", because some use a slightly slanted nut for improved intonation
Instagram
I Like the limba with the bubinga fretboard, it's a really nice tone, i'll get a pro demo done when she's finished
Tv yellow next and a little tease of a moden 59 build with spanish cedar body, eastern maple cap, i might post a build thread up if people are interested enough
http://i1076.photobucket.com/albums/w449/plexiblues/special%20build/20170205_104234_zpsrsscbsyy.jpg
http://i1076.photobucket.com/albums/w449/plexiblues/modern%2059%20build/20170203_183408_zpsvm8idti0.jpg
One thing that doesn't change is the amount of sanding and scraping etc on a carved top even after copy carving
I'm in the middle of 4 carves and it's tedious
