Truss rod on a Thunderbird
daveyhdaveyh Frets: 684
So, got the girlfriend an Epi Thunderbird, basically it's brilliant but there seems to be an issue.
The bridge is at its lowest but the action is still too high. There is too much relief in the neck but the truss rod won't tighten any more. It will loosen no problen so there's no issue with the thread, but it just won't tighten any more. Any suggestions?
  • ICBMICBM Frets: 72426
    It sounds like it may be bottoming out on the thread. If so you need to put a washer - or possibly more than one - under the adjuster nut to give it a bit more travel.
  • daveyhdaveyh Frets: 684
    Cheers, I understand what you mean, much appreciated!
    Adding to that, don't suppose you'd know what washer is necessary?
    One which is small enough to fit down the hole and is large enough for the truss rod to go through it...
    Do I win the prize for the days most obvious question? Duh!
  • GassageGassage Frets: 30928
    Here's a handy schematic.
    So, you're saying I'm going to need a drill?
