I believe there was a period when the bridges were wrongly positioned - causing intonation issues - so check that. From memory - I'm pretty sure it was a 70s issue.
Martins generally seem more prone to needing neck resets than other brands - check that the saddle isn't unusually low to compensate. This is a temporary cure and robs the guitar of volume, due to the reduced break-angle.
I played an early 70s D18 in Frailers a while back and it sounded stunning. Hope the D35 meets with your approval - it looks a nice guitar.
(formerly miserneil)
FF to 49m 13s:
