I had an intermittent 'motor-boating' noise on my Laney VC30-10. Following advice from ICBM I changed the phase invertor 12AX7 and it was fine for a while, but then it came back. Was just about to take it to my amp tech guy to look over and then a thought hit me. Try it via a a different power socket - and sure enough no noise. Plugged into the offending socket, and there was the noise again.
I can't believe I missed such a blindingly obvious thing to try, but it was clearly picking up noise from another device plugged in the ring-main on that circuit somewhere. My Marshall 8080 VR80 was plugged into the same socket but wasn't affected & which is why it never occurred to me before. I can only assume that the Laney was more sensitive to it as its a valve amp. And I checked it wasn't the 8080 causing the problem as I unplugged it when I was trying different sockets, and I've now connected both to the unaffected socket, and all good.
So, if anyone else should hear weird stuff from their gear, the moral is - check the blindingly obvious stuff first as it may not actually be the piece of gear itself that's the problem.
Feel a bit daft, but I'm just pleased I've got to the bottom of it.
I then realised I still had my watch on. Yep, gotta love single coils eh?
