Absolutely bombproof and louder than one too - the Special in particular, which I have. At just over 60lb it isn't that light for a solid-state amp but I'm fairly confident there isn't a gig I couldn't do with it - it's capable of really serious volume for a 1x12" combo. The Bandit is lighter at around 45lb depending on the exact model.
If you want a more modern-sounding one that has decent onboard drive tones as well, the first USA-made Transtube series is outstanding and can be picked up for around £100.
Pre-AVT Marshall Valvestates are good too, although are getting to the point where most need a bit of maintenance now -but once done are also pretty reliable.
The Orange CRs (60 and 120) are great if you want something new.
Trading feedback here
The Tech 21 Trademark 60 is great for the clean stuff, if pricey new.
Then there's the whole Roland family of JCs and the new Blues Cubes. Lots and lots on the Blues Cubes on here.
Basically, it has enough power and volume to fill the place as back line in any pub gig; seldom taken it over 5 on the Master Volume. And mic'd up I guess I'm typically running it at 2-3. So, plenty loud.
Great and really wide range of classic rock to high gain punk sounds. Probably not the newer varieties of metal but I don't play those anyway. Does the cleanish into crunch thing from using the guitar volume pots really well!
Does a nice proper clean too, not really sparkly so if that's your bag get a Fender. But you know: Beatles; Van Morrison; strummy stuff; it's all in there.
Takes pedals really well -- though it took me a while to suss out how to avoid over compressing everything.
I've also used a Tech 21 Trademark 60 as it happens and it does really good classic rock sounds too. I had a couple of issues with it. One was the lack of volume. Even with an extension cab it got lost. This was before we started micing amps. The other thing was dialing in different sounds was a bit more of a faff as you'd get radically different volumes.
[Or you could just buy a cheap JVM410 head if you wanted a last hoorah with a valve amp... ooooh, what's that in my signature?]
Quilter get a lot of love on the US forums, Wembley Music Centre (?) seem to be selling heads and cabs. Small, lightweight, simple heads sold as pedal platforms. Cheapest head is £350 but I don't know at what point in the range they become loud enough.
Poor man's Jazz Chorus
I have one available for free ... no-one else has taste though.
Edit - I've written a longer review in the amp reviews section.
