Not sure if this has been posted but I came across this yesterday and found the bit about mic'ing up the cab very interesting. I have a load of IRs that include those microphones and I may try an implement that technique into my recordings; I have always struggled to 'virtually' mic up an amp because I have no real world experience in mic'ing up an amp for recording. I usually plump for an SM57 and move it off centre to take away the harshness and i don't take much time on this stage because I don't understand it (and i compensate with EQ after
Hope you find it as interesting as I did!
Check out my band
Coral Snake if you like original hard rock!
Good video, thanks for sharing
Yeah the bit about the G string helped explain a few things for me! I think this is part of a whole series too so i'll definitely be keeping an eye out to see what other little tips I can learn
It seems pretty interesting so I'll have to give the whole thing a watch when I've got the time to see it entirely.
That's definitely a bridge pickup btw.
Quite often people have this idea that in the world of digital it's better to get a clean, unprocessed signal recorded and deal with it later, but this is an example of where EQ'ing on the way in makes real, practical sense .Because you want your various mics to be in phase with each other, and EQ'ing changes the phase relationship between the mics. So if You EQ while placing the mics, then you know you've got the sound you want AND the mics are all working together in the way you intend so there's no surprises down the line when you, say, engage a high-pass filter on the room mic at 80hz and lose all your 100hz punch.
Bandcamp
Spotify, Apple et al
When I said stick 4xSM57's up there I was talking hypothetically and just trying to reinforce my point through absurdity I guess! Thank you for your answer though. Always interesting to hear and see different approaches.
I do enjoy that guys videos. Always interesting
So an EQ would be a very crude tool to counteract phase issues, but if you could EQ while being able to move the mics, you can set up the whole system including EQ to sound the way you want, including the phase relationship between the mics which changes as you EQ each mic.
For anyone interested in mixing it's an interesting area to think about - say you want a more punchy snare drum at 200Hz. You boost 200Hz on the snare track but now the 200Hz there is phase shifted with 200Hz on the overhead mic tracks, so not only do you get partial cancellation between those channels fighting your boost, the sound is also smeared in time - it gets inherently less punchy.
When I realised that, I started seeing the benefit of EQ'ing tracks together at the bus level. Of course, phase issues are only issues if they're ruining the sound... sometimes it doesn't matter or improves things.
Bandcamp
Website || Feedback Thread || PayPal
