I am looking for a small (tiny) bass amp for use beside my computer. This is where my Pignose lives and I use the Pignose for bass when watching instruction videos on the web. The Pignose is in daily use for guitar too. A bass amp that is around the size of the Pignose would be perfect, if such a thing exists. There is not enough room beside the computer desk for my Minimark or else it would be used. Suggestions please or if you have 'the answer' and are selling it, please let me know.
Nil Satis Nisi Optimum
https://www.blackstaramps.com/uk/ranges/fly-bass
Most have a time limited free demo available though.
Focusrite make some lovely modestly priced interfaces (I have an older one) but there are many makers now.
BUT - carefully check your PC specs. You don't want any lag. Be sure your PC can cope. Just using an amp sim uses less power than recording or using multiple sims at the same time, but better safe than sorry. You don't want to buy an interface and a few amp sims and then find you need a new PC.
If you have a smart phone - there are free versions of Amplitude available with 1 bass amp on it (small fee for adding them). You could then run the headphone out into your PC.
You'd need an interface for the phone, like the iRig or the Sonicport etc and they tend to be a little cheaper than a PC interface, and you can take it with you if you ever take your bass on trips.
I have the SonicPort for use with my phone, and I use it with the smart phone version of Amplitube. Amplitube can import from iTunes as well, so it's easy to play along to tunes for practice.
They have a good reputation. Bit pricey for a practice option though.
The MB Minimark has an XLR direct out!
@Rocker - you could use that with an interface. Just run an XLR cable from the Minimark into an interface. That way you are using the amp you already like, and you won't have to worry as much about PC spec.
I'd like to see it on a normal desk for size comparison.
occassionally an Eden Nemesis combo pops up on here for <100 and they are hands down amazing sounding wee amps
good for guitar too
http://i1230.photobucket.com/albums/ee495/RockerDIY/IMG_0420_zpsjgavfn2w.jpg
Bottom left is the Pignose, above it is the Blackstar Fly Bass amp.
