Hello people -
Took my new board to rehearsals tonight. Seems to be a problem. I can't get my BOSS DD7 and my EHX Freeze to cohabit. The DD7 cuts out (the power light starts dims and starts flashing and no signal passes through). If I take either pedal off the board there are no issues - but together, they can't seems to get on.
I have a Dr Tone PSU power supply, then, in this order BOSS TU 3 Tuner, Exotic EP booster, Ibanez mini tube screamer, EHX bad stone, BOSS CE - 5, then the EHX Freeze and the BOSS DD7. I tried changing the order of the pedals - no help, and the pedals individually work fine......
Any ideas? Help gratefully appreciated....
Edit - Just realised this is answered above.
Does the Freeze come with a power supply? If so, just use that.
Thanks lads - hopefully that is the problem. I have a fuel tank junior and a couple of 9v adaptors that I could use to do the Freeze or the DD7. I try it tomorrow.
Again. Appreciated.
If there's a manual in with the Dr Tone it should have the figures on it.
I couldn't find a total output figure for the Dr Tone but your pedals would total around 300ma so you'd want a total supply of 450ma or more to be sure I think.
@EricTheWeary yes - the Dr Tone has several different power outputs so I could try one of those - I've only used the 9v outputs.
My mistake - I thought the Dr Tone was a cheap solution but I don't think its up to the job. No such thing as a free lunch and all that. I don't know how you people worked out that it was a power issue....
You can buy isolator adaptors (at £19 per pedal/adaptor for the one pictured)designed to stop that hum but that's getting pricier and taking up more pedalboard space.
https://bobblepic.com/images/2017/01/18/IMG_1013.jpg
Using separate outputs from the Fuel Tank Jr, which has isolated outputs, for the digital fx and a daisy chain from one output for the analogue ones should work. Things like overdrives typical use less than 20ma and the Jr has 120ma per output so that should be fine.
EHX will probably have quoted a high figure for the power consumption of the Freeze because manufacturers tend to err on the side of caution. So it should be okay with the Jr, in theory it shouldn't work at all with the Dr Tone on it's standard 9v outputs.
It's worth it future proof yourself. Even if you get solve your issues now, you might want to buy something else digital in the future.
