DIY spot levelling
I have a guitar with a high first fret which means that the low E always buzzes when you play it open. It is other wise well set up and plays well.
Can I use an emery board and those abrasive fret rubbers to take the first fret down a touch?
Cheers!
    Are you sure it's the fret that is high rather than the nut slot that is low?
  • FelineGuitarsFelineGuitars Frets: 11594
    Likely to be low nut rather than high first fret
    If you lower first you could risk note played at first buzzing - better to raise nut
  • ricorico Frets: 1220
    I can't really tell but I'm assuming there isn't an easy way of doing this at home? It's just the low E that needs fixing.
  • I'd put a bit of thin paper or something under the E string at the nut to see if that fixes it.  If it does, leave it like that until you can get the nut sorted out.
  • You could try the baking powder and super glue method to fill the offending nut slot, then recut with an appropriately sized file. Lots of info if you Google.
