The 70s Strat thread combined with listening to a lot of Garcia and Robbie Robertson of late prompted me to get mine out of its case where it has been for a couple of years whilst I have played various humbucker and P90 equipped guitars. First thought, ooh I had forgotten how much I like this, second thought, what's going on with the pickups? Then I remembered that I had wired the bridge pickup to the mid position so I could get bridge and neck together in a Tele kind of way which sounds rather good I think. So I can't get middle and neck which was the setting I raraely used but still have the all important bridge and middle which I do use quite a lot plus that bridge and neck sound.
Anyone else tried this?
Also has anyone tried one of those Seymour Duncan Twang Bangers which are supposed to give a bit more of a Tele ish bridge sound?
This is the truth from hillbilly guitars!
I had a Twang Banger once - it was good, but it still sounded more like a fatter Strat than a Tele. The key to the Tele sound is the bridge, not the pickup.
Yeah I've got 3 Strats with the bridge/neck pickup combination, its a great sound and somewhat Tele. I've wired mine all using a superswitch which means I can have the bridge/neck combination in place of the bridge/mid position and everything else stays in the same place.
I've also got a Twangbanger in one of my Strats and yes it sounds a bit Tele. It's a bit hotter, has a bit more growl and a bit more mid than a Standard Strat pickup, also a little less top. It doesn't have quite the fullness of a Tele bridge pickup, but is great pickup in it's own right particularly to beef up the bridge position sound.
Strange that this should come up and also mention the TwangBanger, I have one of those and a pair of Alnico IIs I intend to use in this wiring scheme... eventually. Not sure which guitar they'll go in though.
I've also get a baseplate on the bridge pickup, which beefs it up slightly and might put it a bit more into Tele territory. A baseplate would be cheaper than getting a new bridge pickup. The twangbanger isn't just a Strat pickup with a baseplate, but it has a baseplate for a reason because that is part of sound of the Tele bridge pickup.
Having said that, a large part of the Tele sound is the way the pickup is mounted in the bridge itself. You will never replicate that on a Strat unless you go for something like this:
Edited to get picture to show and for clarity
I saw a six-way blade switch that promised to do exactly that being advertised in the pages of Guitarist magazine about a hundred years ago, but I've never actually seen or heard one in the wild...
And, @ChuckManual, replacing one tone pot with a push-pull to add the neck (or bridge, depending on taste) directly to the output lug of the switch would indeed be the easiest option to achieve what you want.
Last time I looked they were only £60 on HotRox's website. Afraid i'm not intending to get rid of mine
It differs from a regular Strat in having master bass and treble controls instead of two tone controls for different pickups. Worth a bash if you're in to alternative Strat wiring schemes.
Yours thankfully,
A.Wiring-Dunce.
Of course with a Strat there are many many options
I appreciate many don't want to drill holes in their scratchplates though.
I have a push/push pot on a 3 pickup guitar that adds bridge to neck and vice versa.
