Bandcamp
Spotify, Apple et al
But my guess is also Super Distortion. Common pickup and commonly in that colour scheme
Instagram
I guess my next question would be, does anyone have any experience with those? Any sound references?
Bandcamp
@TheGuitarWeasel will have more info on why the old ones are different.
I think a lot of Iron Maiden has super distortion on it - Murray and Smith are both still listed as artists and I'm sure they came up a lot while researching this pickup (I went for a bright green Evo in the end, as you do).
I also think The Offspring used them, definitely Dexter Holland.
It could also be a Super 2, though that's less likely than the Super Distortion.
That probably helps answer my next question, then - so with the Super Distortion there's no dedicated neck+bridge versions, the Super 2 is the neck version of the Super Distortion?
Bandcamp
Square feet disappeared in 1980 - so its a Dimarzio from sometime between 1980 and 2004
I agree its mostly likely an SD, but just to give an idea of the number of hex poled DiMarzios available "about 13 years ago"
Breed - 1997
Dual sound - 1974
Evo - 1993
Evo 2 - 2004
Steve Morse - 1983
Steves special - 1995
SD - 1972
SD2 - 1977
SD3 - 1994
Instagram
good spot on the screws though, that should be a dateable feature change.
Instagram
My late 80's Paf Pros (pink, obviously) definitely have the DP151 stamps
