2. Are they valve amps ?
I should point out that the Deco is running from 1 outlet of a Palmer Triage splitter which makes it a fully isolated loop in its own right with a ground lift , phase reversal switch if needed etc .There are other amps fed from the other 2 outlets so I could actually play 4 amps at once if I wanted .
