12 String Kit Build - Finally finished
guitarcookie1guitarcookie1 Frets: 464
edited March 2017 in Making & Modding
Finally got around to starting a new kit build - A 12 string Strat kit from Gear4music that I had for Christmas.
Got off to a shakey start as the first kit had a problem with the fingerboard/neck. The fingerboard wasn't the same thickness all the way down so had come unstuck from the neck, any attempt to fix it would have meant a twist in the neck at the first/second fret.
Anyway, replacement kit is here:
http://i.imgur.com/y33Qbvw.jpg
This is might take a while as it needs to be coloured & finished before assembly so updates to follow in due course
  • Can't wait, what colour ?
    Going for a dark teal colour, tortie pickguard & single chrome toaster-top pickup at the bridge.
    Then crack on asap, sounds great already
  • Some progress in the last couple of weeks - Here we are with the body & neck colour applied, ready for the gloss top coat next.
    http://i.imgur.com/EcfB8gu.jpg
  • Nice colour. You really should put a lipstick pup at the neck too
  • Nice colour choice. Looks good so far. Did you contact Gear4Music with the problem with the fretboard? I bought a jazzmaster kit from them for xmas 2014. Guitar was perfect. Maybe I was just lucky.
    Yes, the first kit went back for a replacement. It was unsavable & would have needed a new fingerboard.
  • Looking mighty fine so far
  • http://i.imgur.com/UJ8Dvax.jpg
    http://i.imgur.com/NeBpM8O.jpg
    Colour & top coats complete, now it can start to go together :)
  • Body looking great
  • Ok, so we're slowly getting there. All wired up:
    https://i.imgur.com/LKlxs9P.jpg
    Problems so far:
    - Pickup route needed widening on the bass side so that the scratchplate would line up with the neck pocket;
    - Control cavity needs to be a little deeper to accommodate the three-way switch;
    - There's no wood under the top hole of the jack socket to screw into;
    - The neck screw holes were too big so the neck currently looks like this:
    https://i.imgur.com/HMWsmgy.jpg
    Hopefully later today I can put the strings on...
  • eSullyeSully Frets: 981
    Looks lovely @guitarcookie1 - The scratchplate and body colour work really well.
  • boydie101boydie101 Frets: 18
    Awesome, I have a 12 string tele kit that has been "in progress" since October.
  • valevale Frets: 1052
    until you put it all together i wasn't into the body colour. thought it looked at bit pastelly.
    but with that retro toaster pickup & black knobs & the 'corned beef' scratchplate, it's got quite a cool west coast late 60s vibe to it. the azure & burnt orange really set each other off.
    congrats on getting so far.
    hofner hussie & hayman harpie. what she said...
    Thank you :)
    It's not an easy colour to photograph properly, it's quite a deep teal in the flesh.
    Now got as far as putting six of the strings on to find that the volume doesn't work properly - at zero it's still letting some signal through :/
    What did you use for the colour?
  • What did you use for the colour?
    Wudtone Lady Teal.
    Was hoping for a more solid colour with less grain showing but I think that would mean applying another bottle of the finish (maybe more)...
  • And finally finished:
    https://imgur.com/gallery/0Bdpk
    Spent yesterday afternoon solving the non-working volume control (forgot to earth the third tab on the pot) and strung it up.
    Really pleased with the result but the colour is really hard to capture in a photo.
    Will probably send it for a proper setup at next string change as the nut is a little high and the frets could do with a polish.
  • Winny_PoohWinny_Pooh Frets: 7769
     Sexay
