I built a chorus - you're gonna need a bigger box
Just finished this, based on the BOSS CE-2. As chorus is intrinsically 80s I thought I would go all out with the art and make it as cheesy as possible.
Unfortunately due to the size of the case and wires crossing over I'm getting some faint clock noise so going to have to put it in a larger case, so annoying!
0reaction image LOL 12reaction image Wow! 1reaction image Wisdom
  • MossMoss Frets: 2409
    Absolutely loving that design
    Stop crying, start buying
  • jonnygreentreesjonnygreentrees Frets: 671
    edited February 2017
    Cheers, I'm pretty happy with it. Was going for an 80s video game box style
    Hope it looks ok on a 1590BB
  • Using a TL022 for the LFO can help reduce clock noise, as can using a separate bias rail for the LFO. It would be a bit of a "kludge" if you've used a PCB, but shouldn't be too difficult.
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • I used a MN3101 for clock with an MN3007 on the Madbean Pork Barrel board, can I sub a TL022 for the MN3101?
  • That is very very cool!
  • 4114Effects4114Effects Frets: 3131
    Have you tried shielded wire where the wires cross? Also using it with a decent isolated psu is a must, clock noise can be a big problem when daisy-chaining. Looks awesome by the way. :-)
  • Have you tried shielded wire where the wires cross? Also using it with a decent isolated psu is a must, clock noise can be a big problem when daisy-chaining. Looks awesome by the way. :-)
    I haven't can you recommend some shielded wire I could purchase?
    yeah I tried it with an isolated supply and it was the same
  • Ah, The Pork Barrel already has a separate bias rail for the LFO. The LFO chip is the TL062. It might be worth trying a TL022 instead, as it has a lower current consumption and shouldn't tick as much.
    I'd try a larger value for C22, something like 220uF, plus a 100uF cap across the LFO bias rail (positive leg of the cap to pin 2 of IC4, negative to ground).
    The graphics are great. I doubt you could get more Eighties if you tried!
    By the way, do you mind if I ask where you got your 3007/3101 from? They are becoming much harder to find at a reasonable price.
    I said maybe.....
  • That's cool as anything, great work
    Thanks man, TL022 ordered, I'll give that a go before I try desoldering any capacitors.
    I got the clock and delay chip from musikding.de
  • SlimbertSlimbert Frets: 336
    Needs the word "Turbo" somewhere on there to be truly 80's!
  • GassageGassage Frets: 30913
    16v.
  • It does sound bloody lovely
    If I have to do a new box then it's definitely going to be the "1986 Turbo Chorus 16V"
  • Not unlike the JHS Ryan Adams offering.
    careful!
  • that does look pretty cool, I was going for more of an 80s video game box art look though
  • DesVegasDesVegas Frets: 4530
    power in sockets should be at the top of the pedal no?
    Should they? I've got loads of pedals with power sockets on the side. Anyway it wouldn't fit at the top, too many components on the PCB up there
