A while back I had a friend set my guitar up, he is an tech and pretty much knows his stuff.
He used an oil on the fretboard, I watched, he put a fair amount on then let it soak for a few minutes then whipped off the access.
I'm not a fan on using oil on Rosewood, my personal thing is it usually doesn't need it unless the wood is worn where it gets played most.
Anyhow, my acoustic in the 12 years I have owned it has never been oiled and it was starting to look patchy and worn in the places it gets the most use, so I decided to use a little linseed oil on it, it came out very nice.
Then I noticed a huge difference between the two guitars, the fretboard with the lemon oil is almost black, I cant see the grain in the wood, its like its been painted over with marmite. The acoustic looks lovely, its easy to see the grain in the wood and its a lovely brown colour as you would expect from a Rosewood board.
So, my guess is too much lemon oil was put on the electric guitar. Its a Squier standard Tele.
So guys, can this be reversed? Can I get rid of this oil? What dissolves it? I refinish/repair antiques so I have a lot of things in my arsenal to dissolve oils, waxes etc.
Any ideas?
A lot of people, myself included, dig the almost black look, it makes it look like ebony and really slick and clean with shiny frets.
There's not really a lot you can do to reverse it, not that would be advisable anyway.
you won't destroy the wood. At worst you might use something that dries it out, but a re-oil will solve that.
Instagram
Also I'm worried about a solvent removing any natural oils but Id say this was at one point kiln dried and most natural oils will be long gone anyway.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Its certainly livened up the grain a little more, it now looks more like wood. I've put on a light coat of Linseed as the cleaning had made the board look very dry and not very pleasant. It looks much much better.
Having cleaned it I'm thinking its just quite dark to begin with and due to all the brown that came off it I'm thinking its been dyed. It is what it is I suppose.
