I bought my 8080 brand new in 1991 when they first came out. Had a service last year and pots were replaced. Over the last month or so its started to howl on the gain channel and I strongly suspect that the 12AX7 has likely gone microphonic and needs changing.
I have a Russian Electro-Harmonix 12AX7 to put in which I think would be a decent replacement. However, the 'gubbins' are all sealed in a 'box' enclosure. If anyone has changed a valve in these before please could you give me 'idiot proof' instructions of how to access this - even down to which screws to undo, any cabling to watch out for, any tricks to make life easier (eg presumably best to lay down amp flat?) etc etc, and where the valve is actually positioned. I've looked on the internet but can't find any clear instructions, vids, or even pictures.
Thank you in advance guys!
@Danny1969 - thank you for that. What am I looking for re the resistors? (I have no electrical tools/meters to check anything)
The only thing to watch out for is to make absolutely certain the amp is not connected to the mains! The valve operates at proper valve voltages so unlike most solid-state amps it's dangerous on the circuit side as well as the mains side.
