Gigging rigs ??
siraxemansiraxeman Frets: 1935
edited February 2017 in Amps
What do you typically use for most of your live gigs? Mostly interested in your amps/pedals/modeller etc rather than guitars.
Moi -
Lately been using my DSL50 2x12 combo (**Limited edition...DSL50 was always a head) with a 1922 2x12 extension cab. And I have a Pedaltrain  2 with a few different dirts on there - TS/OD-3/Dano TOD and a Wampler Pinnacle Deluxe. Also the usual chorus/delay/reverb pedals on board.
I do as well often use the above amp + my AC30HW2X and run all dirt from my pedal board above.
Occasionally run the AC30 with a Red Special replica > treble booster > AC30 dimed and attenuated with a Powerbreak.
What you using for live work ?
«13
  • kennedydream1980kennedydream1980 Frets: 1156
    Blackstar HT5R head into a Victory 1x12 cab (Vintage 30 loaded).
    Warwick Rockboard Jam Pedalboard (Basically a Pedaltrain Mini) loaded with a Maxon Cp101 compressor, Hardwire CR7 chorus, Hardwire DL8 delay, TC Electronic Spark Boost Mini.
    Crank the volume on both channels up to 3 quarters, Mic the cab up regardless of venue and away I go.
    My band are a wedding/pub/corporate event covers band.
  • Fender HRD 3 or Jet City JCA20HV into a Zilla 2x12 cab with greenbacks (or a Zilla 2x12 cab with creamback).
    Pedal board with a tuner, Orange box phaser, Shur Riot/Thorpy Gunshot/Timmy/Spark Booster (depending on mood), MXR chorus, Carbon copy, TC Hof mini and Thorpy modded Boss EQ.
    Used for pub covers and function/party gigs
    ..oh yeah I forgots - I do have a tuner (hardwire) on my board, and a 535Q wah as well in none more black. :lol:
  • Last gig I did (granted, 4 year ago now) was my SG Standard and custom built Cabronita into a Rat, Liquid Sunshine and Line 6 M9 and then a Mesa 5:25.
  • fretmeisterfretmeister Frets: 24345
    Helix into a power amp then a guitar cab or bass cab depending on what instrument I'm playing.
    Ive not had the chance to investigate FRFR kit yet, but if I could half the amount of cabs I own that would be excellent.
    At the moment it's a Zilla 2x12 for guitar and a pair of Barefaced Retro One10s for bass.
    I don't use any external pedals on guitar as the Helix does all I need.
    For bass I have some Darkglass outboard kit in the loops on the Helix but the next firmware update will sort that out, with Darkglass and Pearce preamp models.
    Ive also got a Darkglass M900 head. If I don't need any fx at all then sometimes I'll take that because it's small and light.
    And I can make the amp sound like my favourite clean-ish Helix patch.
  • StevepageStevepage Frets: 3053
    I should be gigging soon so it'll be
    amp:
    Peavey JSX
    RD amp 2x12
    pedals:
    Korg pitchblack
    Boss NS-2
    simples
  • " Why does it smell of bum?" Mrs Professorben.
  • I'm currently running this:
    ...into the effects return of a Jet City JCA22H, courtesy of the AMT F1 preamp at the end of the chain (top left), and then into a Matrix NL212 lightweight cabinet.
    Sounds absolutely immense. I also use just the board for recording direct to my USB interface, with Wall of Sound III providing the cab emulation. This is also immense.
    <space for hire>
  • drwiddlydrwiddly Frets: 918
    My main gigging Rig is Axe FX 2 or Kemper into a power amp (Mesa 2:90, Fryette Power Station or Matrix GT1000FX) into two 2x12 cabs. An FCB1010 with an Uno chip does Midi control.
    Small gig Rig is Axe Ultra and a Digitech gsp1101 into the fx return of a Wharfedale 1x12 valve combo. I keep a Velocity 120 power amp in that rack so I have back up for everything.
  • Pete24vPete24v Frets: 235
    My gig is a function/wedding band. Usually the rig is a 50w Carol Ann Satin into either a Matamp 2x12 with EVM12L's or a Matamp 1x12 with a WGS12L.
    Before that set up I used an 80s Fender Concert for the small gigs, and a 1972 Fender Dual Showman head into an MJW 2x12 with a Fane AXA Alnico & Medusa mix.
    I should probably gig the big Fender rig again!
    Pedals have been pretty constant for the last few years.. KoT, Gunshot & Peacekeeper for drives,
  • RolandRoland Frets: 8714
    Axe FX into PA, with FRFR for personal monitoring. Modified MFC and rocker pedal on the floorboard.
  • Laney Lionheart L20T 112, small pedalboard that changes frequently but all on a PT Jr and I might go smaller. Even that's difficult to place sometimes playing pubs. Pretty much not bothering with overdrives now, although I have two delays which seems quite decadent.
    I don't really need very loud sparkly clean but to cut through against vocals, other guitar, bass , drums, keys. Ska, ska-punk, bit of reggae type stuff.
  • BeexterBeexter Frets: 599
    Cab is an MJW 1x12 fitted with an Eminence Wizard.
    Amp is either a Mesa Express 5 25+ Head or  Orange Rocker 30 Head. The Orange is getting more use at the moment.
    Pedalwise, it's a White Atom or Mojo Hand Crosstown, Barber Gain Changer,  Suhr Koji Comp, Suhr Koko Reloaded, Suhr Jack Rabbit and a Zoom MS100 BT on a Pedaltrain Metro 24.
    I'll occasionally add a Nano+ pedaltrain with an Ehx Superego, Pitchfork,  Zoom MS70CDR and Boss RC3 to the above board for keyboard /pad type tones. Oh, and a Line 6 wireless.
    The whole lot is powered from a single GigRig Generator
    Seriously looking at going AX8 or Helix at the moment with AX8 looking favourite...
  • John_PJohn_P Frets: 2750
    Tiny gigs with limited space.
    Atomic amplfire, Morley wah/vol, polytune into a bogner mojado 1x12 or Friedman asm12.
    Most gigs
    Fractal ax8, EB vol pedals for exp, smoothhound wireless, polytune into the Freidman asm12 or Fender twin with the atomic board as a backup
    New rig I've nearly finished - when some bits arrive will be-
    Smoothound,  Tremonti wah, EB vol, polytune, king of tone, thorpy veteran, boss ce2, dm2, Strymon flint, el capistan running into a Marshall super bass and Jubilee stacks.
  • Fx8 > two rock studio pro 35 combo
  • supessupes Frets: 183
    Les Paul into Stoneham V2-50 with Marshall 2x12 cab.
    With a splash of Bonamassa Wah every now and then.
    Simple like me.
  • Danny1969Danny1969 Frets: 10415
    I gig in 6 different bands so have a few different things
    Used in only one band,  big money corporate and wedding  : Marshall JMP -1 into Marshall EL34 100\100 into 4 x 12"
    Main go to rig for most things : Blackstar HT5 into homemade 1 x 12" with GT10 in the loop ...I do more gigs with this than anything else
    For low volume  laid back gigs : Fender Champion 110 combo with tubescreamer and analog delay
    One thing I've learnt over the years is almost anything will work with  a bit of fiddling
    Helix ... straight to PA these days
    im still abit in shock
  • ReverendReverend Frets: 5002
    Les Paul or Flying with Zombie Dust custom pick ups into tuner (Hardwire or Pitchblack)>Boss CE5>MXR Phase 90>Marshall Guv'nor> Dunlop Q95>Marshall JMP 2203>Marshall TV 1960.
  • DopesickDopesick Frets: 1509
    What ZD pickups are they? I emailed the guy yesterday asking about a p90 version of the Doomsters but still no response...
    My rig is Epi LP Custom 1955 w/ Gibson P90s into Tuner -> Amptweaker Fat Metal (with Mooer Hustle Drive in the Sidetrak loop for lower gain parts) -> Boss DD7 -> Dr Scientist Bitquest -> Matamp GT1 on clean with whatever cab is provided (most of the time a Marshall).
    Thinking about getting a Quilter Pro Block 200 for long distance gigging.
