Weird question but...
GassageGassage Frets: 30930
If I have a unidirectional patch lead, and I want to use it as a bridging cable on a Bright/Normal 4 inpiut amp, and say I am using the bright channel as the main input, which way around does the direction go? Assuming Bright to Normal?
  • RiftAmpsRiftAmps Frets: 3173
    Can you hear a tonal difference between the two options?
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    Isn't there an arrow or something..?
  • Is it made by Russ Andrews?
  • jpfampsjpfamps Frets: 2734
    I can only assume that the cable is shielded at one end only?
    This would not really confer any directionality per se, but maybe useful in breaking a ground loop, however this will not be an issue if you plugging into the same amp.
  • ICBMICBM Frets: 72490
    If it's as jpfamps suggested, with a 'pseudo-balanced' construction so the shield is connected to ground only at the 'destination' end, then either
    It will make no difference since both jacks are connected together by a short ground wire inside the amp anyway.
    or
    It's better to use it 'backwards', with the 'destination' end in the same channel as the guitar cable, since this is closer to 'star grounding' with that as the master ground point.
    or
    I can't think of a good joke about it :). My money's on the first one.
  • HAL9000HAL9000 Frets: 9702
    The giveaway is if it's been liberally coated with snake oil.
