Active pickup battery life
mike_lmike_l Frets: 5700
So, I've acquired a Charvel model4, which has active pick ups (which, incidentally are awesome), but how long (roughly) should a battery last with them?
  • I have no experience with these pickups but most actives last for ages, just make sure you take a spare to any gigs.
  • They last a looong time, just make sure you don't leave a lead plugged into your guitar overnight etc as this will drain them a lot more quickly
    Not quite the same, but I had an acoustic once with an active eq/tuner etc. that took the usual 9v job..
    I actually forgot that it had a battery in it. It was used quite a bit plugged in too.. I reckon the battery lasted about 4 years (!)
  • mike_lmike_l Frets: 5700
    Cheers, the last actives I had were shite, so got replaced with DiMarzio's.
     I've not actually used them for a long time.
    @BloodEagle yeah, I unplug after every time I play. I've made that mistake with pedals before.
  • Danny1969Danny1969 Frets: 10428
    edited February 2017
    The last time I changed my EMG equipped guitar battery was about 3 years ago and that guitar does about 90 gigs a year so in my experience no often
  • SassafrasSassafras Frets: 30297
    Duracell or Energiser will last so long you'll forget it even takes batteries.
    This is very pleasing to hear.
  • BigKevBigKev Frets: 10
    Vigier with EMG's depending how much you use but you should get a good year from a decent battery.
  • Depends on the pickup. Regular EMG humbuckers are 3000h per pickup, or 1500h for a 2 pickup guitar.
    In my esp explorer theres a couple of emg pups. An 81 and a 60. New duracell went in when I bought it, a year and a half later its still going strong. On average its had about maybe 40mins a day over the year plugged in. Some days not played, others for hours.. so average I guess of 40mins ish.
    Theyre 'on' whenever you plug the lead into the jack socket. So like others have said only plug in when youre playing amped, to get the maximum life!
    I was dubious when I first got actives. Thought It would be like 9v pedal life span!! How very wrong I was..
    The most economic battery reliant thing i've ever owned!
