TC SCF
ChrisCox1994ChrisCox1994 Frets: 368
wow, this is thing is amazing...ly impractical.
Does anyone know of a mod to make it run off of a power supply? I read somewhere its actually 15v inside?
I have a truetone CS12 so I can provide it with pretty much whatever volts / amps it needs, does anyone know if its possible?
Thanks.
https://www.gbmusic.co.uk/
PA Hire and Event Management
  • NotNowJohnNotNowJohn Frets: 187
    I'm thinking the same. I read somewhere (probably TGP's jnepo) that they can be converted to run on 18v centre neg.
    I use Gigrig power stuff so no AC and I really need this pedal on my board.
    Any of the resident pedal gurus/makers fancy a go?
  • JohnPerryJohnPerry Frets: 1622
    Google "convert tc scf to take power supply". Couple of threads in the States. Top one has a schematic
  • robinbowesrobinbowes Frets: 3050
    Looks fairly trivial... (I've not actually seen inside an actual SCF)
  • any of the forum pedal experts able to do this?
  • garfygarfy Frets: 144
    I use a dual IEC lead and changed the 3 pin to suit my SCF & the other one for my Gigrig Generator. Not exactly what your looking to do but maybe an option.
  • ChrisCox1994ChrisCox1994 Frets: 368
    An update on this story:
    Took it to my local tech guy. He wired it up for 18v boss style plug in about an hour. Nice and simple according to him.
    Sounds just as lush as it did before as well now and all the pedals now run off of a single power supply :)
