Hi guys and gals. I recently purchased an original blackface bassman head with fitted flightcase on eBay which was described as in full working order and recently serviced. I took it to my amp tech to give it a health check and he says there's quite a bit of work to do to make it good.
https://www.ebay.co.uk/itm/232217215975The replaced transformer is fitted poorly and the chassis is rusty along with a burn mark from a hot valve on the power cable. I think this is all fairly easy stuff for an experienced ampaholic but I don't want to spend any more on it and seller had accepted a return.
https://i.imgur.com/Dv5Kehe.jpgBut here's the thing... it cost me £490 inc P&P which was a good price. Does anyone here want to buy it to save me the hassle of an eBay return? Seems like a great deal if you know what you're doing with amps. It does work and sounds great but I can't afford to spend more on it to make it safe.
The rest of it is standard for an amp this age and nothing much to worry about or hard to fix.
From pictures I can find that transformer is mounted 90 dgrs wrongly from the optimum hum "bucking" position and therefore smacks of a numpty fitter. (and WTF not make a proper adaptor plate?) . It also looks to have a bigger core than the pics I find and therefore is likely to be of the wrong ratio and the amp will not sound like the original, could even bugger valves or/and itself.
Lot of money for a kludge IMHO!
Dave.
64's were still 6G6B, but this looks blackface.
I'd probably send it back if I could, although I guess they would argue that the transformer change was mentioned in the description.
Transformers are the single most expensive items in amps, so any repair requiring a new transformer is likely to be expensive.
The real killer would be if the chassis has been hacked so the correct repro OT can't now be fitted.
The orignal BF Bassman only had a 4 ohm out, so it;s likely that the OT was killed by running the amp into a 16 ohm cab.
I've often seen Fender Bassman with replaced OT where the secondary is whatever the replacement has rather than any attempt to get it "correct!
The Amp Hospital are in my experience very pricey, so you may be able to find a cheaper quote for the work elsewhere.
Solid-state amps don't have an OT (usually) so the danger is from excessive current being drawn through the power transistors, which is why they must not be run into a lower impedance than the rated minimum, or into a short which will kill them very quickly.
So the rules are almost opposite - most valve amps will safely handle a load between half and double the matching impedance, but lower is safer than higher; most solid-state amps will handle any load above the minimum (there are a few exceptions but they're very rare).
Older Fender amps are one of the ones with a shorting switch in the speaker jack, and are generally very tolerant of mismatched impedance, but as jpfamps says, running into a 16-ohm cab (typically an old Marshall 4x12") is one of the few ways to risk damaging them.
@jpfamps @DJH83004
https://i.imgur.com/fWXq39p.jpg
https://i.imgur.com/gLpdPkQ.jpg
https://i.imgur.com/4c2iUZe.jpg
https://i.imgur.com/YeiAd4w.jpg
https://i.imgur.com/vhFN4Y8.jpg
https://i.imgur.com/ozCTwGv.jpg
The good news is that the bias filter cap has been replaced, so there's a reasonable chance the others have been - have a look under the metal cover. The dual cathode caps are original and might be best replaced, although if there's no evidence of leakage it's not essential usually. The screen resistors have also been changed - technically for slightly the wrong value, although it doesn't matter - and one has then been overheated again, so if it was me I would probably replace both with 5W wirewounds (470-ohm).
Also check that the voltage selector has been hardwired for 240V (I can't quite see clearly enough) and do so if it hasn't.
Thanks for the recommendations.
I'm away until the 11th May, so drop a line when I get back if you want us look at the amp.
There is a good choice of after market reproduction output transformers and chokes.
