This really does show why a shunt protection diode is a poor to useless method of preventing reverse voltage damage.
If EQD aren't interested then I'm happy to take a look.
"This really does show why a shunt protection diode is a poor to useless method of preventing reverse voltage damage. "
It WOULD work IC if it was allied with an in line fusible resistor but, "pennies again" of course. Sadly it looks as though the rest of the pedal is borked. That is partly the result of SM technology, the chips are simply not as rugged as DIL ICs (even better in holders which shunt more heat) but if "we" want compact and bijoux and CHEAP ???
Dave.
I remember using the wrong polarity on an ibanez phaser/flanger. Weird box of very cool noises. It looked like the diode was burnt out but it actually is still able to protect from reverse polarity (as discovered when I redid the board) and still works fine with the proper supply. Not sure if it's designed in a different way or I'm just very lucky...
Certainly, but that's two components where only one - a series diode - is really needed, and it would still mean replacing something to get the pedal working again.
Joking of course, nice one stepping up!
