Wah no workie
professorbenprofessorben Frets: 5105
Ok so I popped my recently acquired Dunlop GCB 95 on the board, and powered it up, nothing.
the other pedals work fine off the same plug, am I missing something super obvious????
there no battery in it, does it need one?
cheers
  • ICBMICBM Frets: 72339
    Not if it has a power cable in.
    By 'nothing', do you mean total silence in either mode, or works in bypass but not with the effect on?
  • professorbenprofessorben Frets: 5105
    Nothing =dead when engaged.
    works in true bypass me de (off)
    In that case it's either a faulty switch, a fault in the effect circuit or a bad connection in the power jack. Does it work on a battery? That would eliminate the first two.
    Ahhhh
    you see I thought I was being really clever by bolting it to the board, I fear my enthusiasm overtook my common sense.
    Ill have to unbolt it from the board to check it with a batt.
    bums.
    Hang on
    i have a persistent problem that it's difficult to get the power connecter in properly
    give it a good wiggle
  • hotpickupshotpickups Frets: 1822
    I had a wah once where the power lead end wasn't quite long enough to make a connection. Tried a different cable and it worked
    Cabicular said:
    Hang on
    Good advice for life in general there  ;)
    It's always worked for me ;)
    Cabicular said:
    Hang on
    @Cabicular and @hotpickups for the win, trimmed a bit off the plastic around the barrel of the power jack and hey presto!!!
    cheers chaps.
    I love it when a plan comes together :)
    Can I ask what attracted you to that wah? It's a bit old school these days with all the other options around?
    £40 brand new with 12m warranty.
    Also, it sounds like a wah.
    I also used to own one, in fact it was my very first pedal, my dad bought it for me on my 14th birthday.
    After watching the Dave Weiner pedal show special, I realised its all anyone needs in a wah.
  • 57Deluxe57Deluxe Frets: 7339
    edited March 2017
    1: Mick Ronson's half cocked Wah sound
    2: The Wah solo section in Barclay James Harvest's 'For No-One' (@3.57) I used to emulate it with a 18" Ruler and stapler for the wah when revising my O Levels in the 70s! You can't get more 'Old School' than that!
    <Vintage BOSS Upgrades>
