Hey - hoping someone else has done something similar before & has suggestions!!
Essentially, looking to get a new amp & i'm looking for something thats fairly clean with good headroom so I can use it as a platform for pedals - ideally suitable for small gigs/jam session as well as home use. Tried out a few, and the HRD seems to be the winner at the moment; but it seems to have no 'low volume' and gets loud very quickly - good for band use, not for my neighbours!!
My thoughts are that possibly a tube swap might help (IIRC there are lower power models that will fit the same sockets?) or some sort of passive volume control (like EHX signal pad) in FX loop. (An attenuator would be overkill and just shorten life of the tubes as I'm not looking to 'push' the amp hard, and instead want to rely on the pedals to colour my sound)
Wondering whats the best option to make it work at low volumes or if anyone has other good amp suggestions!
If for some reason that really doesn't work, a volume box in the FX loop will.
Different valves won't make a significant difference - lower-gain preamp valves will make the amp cleaner but not a lot quieter - although may be worth trying, a 12AT7 in V1 works fairly well. Different power valves (it's possible to fit 6V6s, although you need to mod the amp a bit) will simply reduce the maximum volume, which is not what you need.
edit: like this http://www.thefretboard.co.uk/discussion/96542/mesa-express-5-50-1x12-combo-500#latest
Great suggestion - I'd imagined that even second hand the likes of Mesa Express combos would be way out of budget; same goes for a Fender Princeton which was also possibly on the radar for me.
Up in Scotland for the next couple months and its hard to find the likes of those used here for anywhere near that price wise, but will be moving down to London in the next few months (dependent on job situ!), so may just hang off and see what comes up used after I've moved... also I'll have a good bit more disposable cash to put towards it too (even after accounting for higher cost of living)!
Thanks for the help - yeh, I was able to get it just about right using control but there was so little margin, i just wanted to look at any alternatives! and thanks for the advice on the tube swaps as thats something I'm not that familiar with.
You can buy ready-made ones online quite cheaply, eg: http://www.ebay.co.uk/itm/Guitar-Amplifier-Attenuator-Volume-Pedal-Passive-Volume-Amp-Reducer-/141620893968?hash=item20f9435910:g:tG4AAOSwKtlWk9Ft
That's quite a good deal, as the parts alone would cost most of that at UK retail.
(Slightly incorrectly called an 'attenuator' - although technically it does attenuate the signal level, in guitar-amp terms an attenuator is more correctly a *power* attenuator, as you already know.)
Obviously if you disengage the pedal the volume will increase but I've never ever struggled to get a bedroom tone out of my HRD in all the years I've owned it. My Pro Junior on the other hand is a different story!
Until recently I had a Fender Blues Deville 410 which I loved but my back hated.
I live in a central London flat with my wife & 6 year old daughter..... I could dial the volume to about 0.5 & play late into the evening without waking my daughter or annoying the neighbours....
I actually get more requests to calm down now I am using Irig into the Ipad/Ipod as I can't hear the thrashing of the strings
I'm not really looking to try and really saturate the tubes for tone, rather keep it pretty clean - But will keep the LPad in mind for a future project (I might get the folks i've used before for amp repairs to knock one up instead as it doesn't seem too costly for the parts & suspect they will have made similar so could calibrate rough 'tiers' of attenuation as the Dr. Z offers - took a look at a gutshot of one and seems straightforward to do!)
Still more expensive than the volume box though.
I changed the preamp valves to the following
V1- 12AY7
V2 - 12AXY
V3 - 12AT7 (Phase Inverter)
A 12AY7 to the standard 12AX7 in V1 will bring the gain down and make the cleans more manageable.
The next thing is to use the second input, which is much more controllable than the first input.
Not sure if I've asked this before but does anybody have any idea why 25k is the preferred pot value. There's at least one post on another forum where Brian Wampler suggested 100k but didn't explain why.
It makes very little difference, because the loop is properly buffered, with a very low send impedance. Any pot resistance between 10K and 1M will work (at least, maybe even outside that range). A higher value will tend to allow a bit more noise to be picked up, but nothing worse than that.
And thanks for the explanation of 25k v 100k, I'll leave my DIY job alone, cheers
The only way to drive the power amp harder is to make it produce more power, and the only way to do that at lower volume is with a power attenuator between the amp and the speaker.
