No benefit to be had by replacing a fettled and properly cut plastic nut with an off the shelf precut bone nut.
Pre-slotted doesn't mean it'll be optimal when you fit it. You'll probably still have to do a little bit of filing to get the best results. If you don't have the necessary files I'd talk to the tech you're using and ask about the price difference for them to make a nut for your vs you supplying a pre-cut nut that they fit and set up for you. There might not be a great deal of difference and the main advantage comes from the slots being cut correctly.
I've fit 4 or 5 pre-cut nuts myself over the past couple of years and all of them have required a little filing.
