While you're at it, if you open it up and look in the chassis it might need a jolly good clean out, the fan in them can make it quite dusty and grubby inside. Check filter caps for obvious damage.
Make sure the cables to the reverb tank are secure.
Iff that doesn't work, take it to a reputable amp tech...
