http://www.lacemusic.com/Sensor_Emerald.php
In this particular guitar, swapping neck pickups is a right ballache, so I want to try to make the right choice first time round.
I've just recently bought a new pre wired scratchplate with red/silver/blue sensors and a super switch (7 way toanz on tap adding the neck in to whatever you have selected) - they match well and are sold as a 'calibrated' set. the blue is like a fat p90'ish sound....with this set you do lose some sparkle and twang but you do gain more beef. Golds are the nicest sounding for trad strat toanz....but not as good for dirty sounds. I've had hot golds about 10yrs ago and they was ok to.
It's a long time since I've tried Lace Sensors, but around 1989 I had one of the early Strat Plus Deluxes with Blue/Silver/Silver. When they changed the spec I copied it and got Red/Silver/Blue, but I remember I preferred the original setup!
check this guy out http://xhefriguitars.com/page2.html - probably the definitive info on Strat Plus models
in fact the HS2 is the pickup I always default to for a great sounding singlecoil.
@grungebob maybe I will try an HS2!!
