Been a fan of the Pog2 for a while, esp with bass guitar and have just picked up the Bass Microsynth which is also an insanely good effect generator. While each pedal sounds excellent alone (with compression, phaser and chorus) I haven't found a way to use them together, in fact their sound sets almost clash. Has anyone run them together and if so any recipes?
The bass micro synth is an incredible noisemaker. I was a bit wary of getting it as a lot of vids have led on its metal or funk tones and I wasn't sure if it could sound gentler and spacier - and it can, in spades. Compression before helps to shape the sound that the micro synth receives and delay after helps control the trigger/gate on long notes. Small changes to the sliders can alter the sound hugely. Incredible fun and very inspiring soundscape wise.
SaveSave
Are there any small devices that can simply split the signal to A and B streams?
EDIT: here you go
https://www.andertons.co.uk/p/MOOABY/aby-and-switchers/mooer-micro-aby-mk2-swticher-pedal
