Assuming the guitar still as the neck on it:
Measure the scale length - that is, the length of the freely vibrating part of the string from the nut to the bridge saddle.
Typically for a strat 25.5 inches (just under 650mm). If a couple of inches shorter, it's a 3/4 scale or so. (Note "3/4" is not an exact fraction, it's never three quarters of the full scale length, it's a bit arbitrary.)
If you're going to replace the neck, you'll also need to consider the width of the neck pocket. That might be a bit more tricky - maybe someone else knows the exact standard widths?
Instagram
