I've used their own thumb-lock tuners for a number of years and, at first, was a little alarmed that they seemed to be phasing them out. Somewhere along the line I'd missed that there had been any change. I emailed Craig at Axesrus who explained that the original lockers were being progressively replaced by a new custom design of lightweight locking tuners.
First impressions are VERY good
Bear in mind they do not do a mixed gold and black (I bought two sets for this build so I could mix and match the components from a black set and a gold set) but regardless - they are beautifully made. And they are noticably lighter than the originals. And they are more stylish. And I have no doubt whatsoever that they will be just as reliable as their predecessors.
Assuming they do indeed perform as well as the old ones, these will be going on all of my 6 string builds from now on.
And no - I'm not on any commission
I will do one last tweak once the guitar is finished and all strung up but to get it pretty close, I go by feel and then, holding the guitar a bit like a back to front cello, I use a scraper - drawing up the neck length very lightly - to take away any lumps or bumps along the length or facets around the profile curve.
And that's it! Basic build is complete and finishing has now started
I use a variation of @WezV's excellent tru-oil method as a combined sanding lubricant, grain filler and sealer. The body will actually be gloss varnished eventually, but I have found this method to be just as good as a gloss prep method as a finished method in its own right
The only difference (if at all) is that I probably use coarser abrasive cloth at first - typically 120 grit but sometimes even 80 grit.
This is the first application following the normal 'final sand':
Five minutes later, I have this:
And then fifteen minutes later I have this on the back and neck too:
The slurry from the sapele, wenge and purpleheart will, if not wiped off, discolour the maple, so I always wipe off the wet tru-oil from the maple even before I start the actual slurry and buffing.
When dry - this will look a bit naff - as the oil soaks in differentially. I will probably repeat with a coarse grit once more, once it has fully set, before starting the proper slurry and buffing Sunday/Monday-ish
In the meantime, to MrsAndyjr1515's delight, there are a couple of small guitar and bass jobs that have been waiting a while that I'll be getting on with.
Other than leaving it for a few days for the tru-oil to properly harden before I gloss the body, it's already ready for just that!
If this had been a satin finish, it would actually already be in its final finished state!
However, the gloss will be worth it...it will make SUCH a difference to the figuring of the top
I told you that the gloss would bring out the figuring...
The additional coats will bring it out even more.
Just because you're paranoid, don't mean they're not after youMy Trading Feedback | You Bring The Band
Just because you're paranoid, don't mean they're not after youHow's the health?
Just because you're paranoid, don't mean they're not after youOn the mend, I think... its been a long road.
Just because you're paranoid, don't mean they're not after youThe neck will be left unvarnished - the @WezV truy-oil slurry and buff method has to be felt to be believed on a neck...
Meanwhile, the top and sides have had their second coat:
Well - I may have got to the 'Yes - that's pretty good' stage quite quickly on the back. While there are a couple of things I'd tweak if I was doing a further coat, this in real life looks pretty much there:
The top needs one more coat at the very least - and sometimes that will result in redoing the back, in which case I would make the further tweaks - but we'll see how it goes
