Amps which sound better at low volume
JohnPerryJohnPerry Frets: 1639
Just curious. Are there any that sound better at home volume than they do cranked?
I can think of a few that sound better switched off.
But don't all quality amps really sound better at decent volume? Even those with really good attenuators always seem to sacrifice something when down low
  • RiftAmpsRiftAmps Frets: 3285
    I’ve never heard a valve amplifier that sounds better at low volume than it does turned up.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • Strat54Strat54 Frets: 2509
    I've never found one....but I've not tried a Carr Mercury on say the 1/4 watt setting.
  • thecolourboxthecolourbox Frets: 10325
    They might not sound better at low volume than they do louder but that's not to say they don't still sound good. A Squier Front man 10 watt practice amp probably sounds its best at low volume but doesn't mean it sounds anywhere near as good as a valve amp at low volume
    I'm scared and I'm waiting for life
  • martmart Frets: 5213
    I know some amps that sound best when the volume is at 0. :)
  • p90foolp90fool Frets: 32367
    I'm saying nowt...
  • ICBMICBM Frets: 74281
    Fender Blues Junior.
    At low volume, with the master, bass and treble up high and the volume and middle low, you can get a reasonably nice Fendery clean sound out of it.
    At higher volume the more typical shouty, overcompressed, muddy, boxy tone can't be dialled out, and if you try it just becomes farty and mushy.
    However the original question did say *quality* amps, so the Blues Junior may not qualify anyway ;).
    I said valve amplifier, not ‘amp with valves’ ;)
    Rift Amplification
    www.riftamps.co.uk
  • gordijigordiji Frets: 815
    Roland Blues Cube 40xl, sounds great quiet & pants loud, especially on marshally settings.
  • DominicDominic Frets: 16567
    NO,.........it sounds quite good dialled down but the last 2 settings are poor IMO which is true of most attenuators ...they work really well until you get down to the last 30 per cent.
    Fender bassbreaker 7
  • Modulus_AmpsModulus_Amps Frets: 2658
    it is not just the quality amp issue, guitar speakers only sound good when you turn them up and get them moving a bit.
    correction Roland Cube 40xl, don't know where the blues came from.
    I don't agree at all. Most guitar speakers sound fine at low levels - the V30 being a notable exception, but even that only needs a few watts to wake it up. In my opinion 'needing to push the speakers' is one of the huge myths about guitar amps.
    1reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • slackerslacker Frets: 2300
    My Matchless sounds awesome clean at very low volumes. It depends what you want from an amp. I always want cleans that work well with an overdrive regardless of volume and venue.
  • I have a Marshall sl-5 It has proved to be a great.amp at low volume. It has a great clean and overdrive sound at just above talking volume.
  • JohnPerryJohnPerry Frets: 1639
    But does it sound better quiet than when it's cranked?
    I can't hear amps very well when they are cranked to be honest just sounds like loud guitar to me. I can hear them much better when reigned in a bit and then all of a sudden I can hear tone again
    edited January 2018 tFB Trader
    it is OK to disagree, bare in mind I said "get them moving a bit" I didn't say "push them" which implies something else. Also a few watts can still be too loud for most homes and it is very hard to know how loud someone else plays at home.
    But fact is our ears respond differently at different sound pressure levels, cabinets respond differently at different sound levels and speaker respond differently at different sound levels, guitars react differently to the amp at different sound pressure levels, point is there is so much at play beyond the amps power output...
    No but I don't want to take two amps out.
    are there any particularly low efficiency speakers that sound good but would negate the need / impact of attenuators and still allow an amp to be opened up a little ?
     I also seem to remember seeing a speaker with some sort of volume management in too - any good ?
