Right then my lovelies.
Welcome to the first "Mastering Challenge" as suggested by mr
@flying_pie... (who will add a few more outline rules/suggestions shortly)
Rules is simples... Take the supplied mixed track, sprinkle some magic pixie dust on it and boom... Musical gold!...
A few guidelines...
when you send your submission, post a bit about the process you used to get to the end result... what software? what plugins? what outboard gear? etc etc. (a screen shot of your master channel will be useful)
The track is a slice of pop/funk penned for the new Mrs Pot (and named after my lovemaking prowess)
You can download the non mastered WAV below...
https://soundcloud.com/thefretboard/3mins-nonmaster
your target listener for this one is "Joe Hipster".
Joe lives, works and plays in Hoxton... He gets his music from a streaming service and Listens on the go using the most expensive "Beats" he could get (apart from night time when he just wears earbuds to avoid the muggings)...
At home Joe listens on his various Sonos devices as he moves room to room sipping a chai latte in his overpriced 2 bed apartment.
Send your submissions to mix@thefretboard.co.uk as an mp3.
Voting will start soon after the submission deadline of 22nd Feb 2019 with each voter selecting their 1st, 2nd and 3rd choice.
First choice gets 5 points - Second choice gets 3 points - Third choice gets 1 point
Voting will end on 11.30pm 28th Feb 2019
The order and scores of the top three entries will be announced soon after the voting ends. If there are 8 or more entries, then the order and scores of those in the top half will be announced.
No prizes. It's just to help me get laid for fun.
****** NOTE******
No Cheating... as in no "Landr"...
If people are interested I can explain my process.
I didn't use Landr, or many plugins.
Here are two versions of it uncompressed on Soundcloud (.wav)
First one is hot and crunchy- this is the one I submitted as it fitted the posted brief.
Second one is more subdued- I prefer this one.
Football is rubbish.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
https://soundcloud.com/thefretboard/sets/mastering-challenge-no1-3mins
Not lot done really. I try not to mess too much with masters - however as the brief was headphones, and Beats, I shaved the top end and boosted the bottom, some multi band compression with higher ratio and gains at the lower and higher freqs. There's a splash of room reverb (only 5%) to gell it a little (probably didnt need that), then Ive widened the mix as the target audience is a headphone only user to give it loads of space. A limiter at the end to squeeze as much volume as I could for the target.
Its far too in your face for me personally - but though it fit the brief more.
When it comes to judging - Ill be doing it over my daughters Beats headphones as thats what the Brief calls for.
If I am out of line here then just say- hopefully it helps someone.
First, a word of caution regarding phase.
When you take things super-wide you can end up with some weird artefacts.
Also make sure you top and tail the audio.
When you mix or master then the final processing is usually a two step process.
Put a bar at the start and end of your mixed or bounced down 'final'.
Then trim the start and end of the audio file, so you have a natural end to the track- you don't want it to chop off suddenly at the end, nor do you want loads of space at the beginning or end.
Finally- if these are being mastered 'for headphones', be aware that headphones usually have exaggerated bass response- a bump about 80-100hz and then rapidly tailing off.
If you have processed with extra bass you might find that on headphones you end up with the bass being overbearing.
If you've added widening processes that affect the entire mix then you can also end up with a weird feel to the track, because instruments like kick, snare and bass guitar, that were mono are now a sort of faux-stereo.
Some widening software (Plugin Alliance/Brainworx in particular) allows you to work in Mid Side, so anything that is low pitched and centre is unaffected by stereo widening.
I'm very inexperienced in mastering, but I've been learning as much as I can recently. The things I tried to achieve in my master are as follows:
1. using a mid-side EQ to bass boost in mid to bring out the bass and kick drum which is really carrying alot of the push in the song
2. using a mid-side EQ and hi cutting in mid to subdue the overly-prominent tambourine (when listening to the original track, it feels like I'm having a tambourine being waved incessantly in front of my face)
3. normal EQ to boost presence of the rhythm guitar center
4. using a mid-side EQ to define and separate the panned instruments (i.e. keyboard, flute, sax and a few more)..
5. EQ to smoothen the overly brittle highs
6. Compression and limiter to achieve loudness
7. last minute addition of bit of verb to wet the somewhat dry track (only cause I saw what @paulmapp8306 said he's done)
If Id mastered for general use (headphones and speakers) probably wouldnt have widened the mix. However, its a learning curve for me so Im taking all advice and tips on board for the future. As I know @octatonic 's background, I expect his mix to be the benchmark and as always take his advice as gospel.
Due to household factors I am required to mix and master with headphones. Yes... I know.... Anyway I didn't add a stereo widener as it seemed wide enough to start with
