Daft question: how do you weigh a guitar?
4string4string Frets: 34
in Guitar tFB Trader
I would have thought fishing scales would be ideal, but not having any of those to hand... Your tips please on weighing (reasonably accurately) a guitar. Extra points for style :-)
Chief Bottle Washer @ Oil City Pickups.
  • Get a set of digital scales, weigh yourself, note the weight.  Weigh yourself holding the guitar, subtract what you weigh, and you'll get the weight of the guitar.
  • LewLew Frets: 1657
    Run a bath. Drop the guitar in and see how much the water rises.
    14reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • strtdvstrtdv Frets: 2587
    ^ This seems like the obvious answer.
    Don't forget to make sure the water gets into all the control cavities.
    Next question has to be "will my les paul float?"
    Seriously though, a small set of digital kitchen scales will get you a reasonably accurate result, or alternatively hang the guitar by its strap off a set of luggage scales.
  • 57Deluxe57Deluxe Frets: 7397
    edited August 2014
    I have one like this.
    Make a sling to go round and about your headstock and tuners and place the base cushion from the sofa on floor and weigh your guitar over top - is no need to be held more than a few cms from the floor/cushion...
    If you got dickie eyes, you may want someone to take the readings for you...
    <Vintage BOSS Upgrades>
  • DiscoStuDiscoStu Frets: 5727
    That's the weigh (!) I do it.
  • meltedbuzzboxmeltedbuzzbox Frets: 10343
    if it floats its a witch and you burn it
    Weigh-hey!  >:D<
  • 4string4string Frets: 34
    The thought of getting on the bathroom scales with or without a guitar does not hearten me... :-)
    Didn't think we'd have to weight long for the cringey jokes to start.
  • It is just the weigh of the world these days.
    Just wear shoes and lots of thick clothes and blame the weight reading on them.
  • vizviz Frets: 11018
    Insert joke about scales.
    sounds fishy
  • richardhomerrichardhomer Frets: 24989
    I tend to only use the penatonic.
    Apparently the chromatic's the most accurate....
    Are you using a Tuna?
  • HAL9000HAL9000 Frets: 10061
    If it's a Les Paul you can probably get an indication of its mass by seeing how much a beam of light bends around it.
  • LevLev Frets: 228
    If you have a case, try stand the case with the guitar inside on a bathroom scales. Then subtract the weight of the empty case.
  • ICBMICBM Frets: 74281
    Er... I get a set of scales and put the guitar on them. Why make things more complicated?
    The tricky bit starts when the guitar is an awkward weight, like 8lb 15.5 oz. Under no circumstances must you admit that it weighs (rounded to) 9lbs - that will kill the value stone dead even if it's the best-sounding '59 Les Paul ever made. The correct weight in these cases is "EIGHT POUNDS
    fifteen ounces" or "about eight and three quarters pounds".
  • fretfinderfretfinder Frets: 5212
    edited August 2014
    Buy some flat-topped digital kitchen scales that weigh up to 11lbs/5kgs. They are reasonably cheap, accurate and I've weighed Strats, Teles, Les Pauls and 335s etc very successfully and accurately with them. You just balance the guitar flat with its body on the top of the scales.
    If the scales bottom out then it's probably a Les Paul and all you need to know is that it's uncomfortably heavy and you should probably get rid!
    You can also use luggage scales or fishing 'spring balance' scales successfully. Bathroom scales can be unreliable in my experience as they're designed to weigh several stones in weight (10s of kgs for the youngsters) rather than 5-10lbs.
    Edit: no way is this a daft question, it's probably the most sensible question on here!
    260+ positive trading feedbacks: http://www.thefretboard.co.uk/discussion/57830/
    Borrow a lorry, take it to nearest weigh bridge....
