What's the ideal order of tasks when setting up a guitar?
I'm guessing...
1. Check the frets and make sure they're level... and deal with any high/low frets.
2. Check depth of nut slots... and file as necessary.
3. Check and adjust the neck relief.
4. Check saddle heights... and adjust as necessary.
Is that correct... or total tosh?
Thanks.
I would add...
5. Intonation.
6. Pickup adjustments.
... and:
0. Check everything is working and at least in the right ballpark *before* you start! It's annoying to have to take the strings off again to get at the electrics, or a neck joint that needs shimming, or something like that. (Guilty, many times... )
@ICBM... yes... I should've added all those to my list! Thanks.
An additional question...
If I don't want to get involved in filing/levelling frets... and just want to assume they're OK-ish (after a cursory check)... I guess it would be wise to allow a little bit of wiggle room when adjusting nut and saddle heights... i.e. if we're talking about an acoustic, take care not to remove the theoretical maximum amount of material in the nut slots or saddle height, just in case slight unevenness in the frets could introduce buzz.
Does that sound sensible?
Instagram
So I guess you're saying it's a dumb idea?!?!? :-)
my own acoustic plays perfectly for 6 months of the year, buzzes and rattles for the other 6. I should have left a bit more wiggle room in the saddle height, or done the set-up 6 months later. I will sort it net year, maybe
Instagram
@WezV Many thanks for the info.
... and with regard to your acoustic buzzing for 6 months of the year... that sounds like the perfect excuse to buy another guitar... so you've got a summer acoustic and a winter acoustic. ;-)
Instagram
Yes... I've been meaning to sort out a summer saddle and winter saddle... but I'm always happy to find an excuse to buy another guitar (even if my wife isn't)
What is and isn't ok to do under full string tension?
In my mind, I work to this but not sure if it's general wisdom though?
OK = truss rod, saddle string length (I.e intonation), saddle string height.
Not OK = post height on TOM or fender 2-post trem etc.
And one more: should you grease mechanical components (I.e trems) from time to time?
The big ones to never do under string tension are -
Post heights or intonation on a wraparound bridge/tailpiece - you *will* chew up the posts with the tips of the intonation screws, and probably the slots in the top too - which also applies if it's just a tailpiece. (NB, these are intentionally designed as *coin* slots - don't use a screwdriver, use whichever coin is the best fit.)
Floyd Rose, other 2-post knife edge, and PRS trem pivot screws - you will damage the knife edges.
It's OK to do both these with some minimal tension on just to keep everything in the right place, you don't have to take the strings right off.
Truss rods are also OK under tension, but it's often better to pull the neck back a little by hand at the same time to reduce the force needed on the nut.
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
Your generosity has been duly awarded... with a Wisdom - to replace the one you kindly passed on to ICBM!
Very apt in my case. I've recently taken to wearing two pairs when trying to do something particularly tricky.
