I put the bridge from Axecaster on mine. I seem to remember some info on the Axecaster blog. Also, Gavin from Axecaster hangs out on here as @gavin_axecaster and may be able to help you out. The bridge he sells is very nice for the money - certainly better than the original one fitted to mine.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
The bridges on the Mexicans stayed the same but Fender changed the string through holes on the body to match the bridge on the 2013 and later models (CAR/SG and Thinlines). On the original 2012 models the body holes were 52.5mm spaced and oversized, hence working with both a 52.5 and 54mm spaced bridge.
http://axecaster.co.uk/blog/?p=1447
I took it that he was in work/not at home and was wanting to make an order.
apologies
